I am using an nfs mounted partition (/scratch) to compile on, so I'm hypothesizing that my problems are related to the network driver.
Any thoughts are welcomed.
[ 2455.534291] INFO: task ld:24879 blocked for more than 120 seconds.
[ 2455.538489] Tainted: G C 4.14.31-1-ARCH #1
[ 2455.542688] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 2455.550990] ld D 0 24879 24804 0x00000000
[ 2455.555379] [<80a87848>] (__schedule) from [<80a88018>] (schedule+0x3c/0xa0)
[ 2455.559662] [<80a88018>] (schedule) from [<8015c138>] (io_schedule+0x14/0x3c)
[ 2455.563990] [<8015c138>] (io_schedule) from [<80230be4>] (wait_on_page_bit+0x110/0x15c)
[ 2455.572326] [<80230be4>] (wait_on_page_bit) from [<80230d0c>] (__filemap_fdatawait_range+0xdc/0x128)
[ 2455.580865] [<80230d0c>] (__filemap_fdatawait_range) from [<80233190>] (filemap_write_and_wait_range+0x54/0x88)
[ 2455.589272] [<80233190>] (filemap_write_and_wait_range) from [<803db1c4>] (nfs_file_fsync+0x30/0x280)
[ 2455.597837] [<803db1c4>] (nfs_file_fsync) from [<802d5dcc>] (vfs_fsync+0x24/0x2c)
[ 2455.606295] [<802d5dcc>] (vfs_fsync) from [<8029d758>] (filp_close+0x2c/0x80)
[ 2455.610675] [<8029d758>] (filp_close) from [<8029d7cc>] (SyS_close+0x20/0x48)
[ 2455.614999] [<8029d7cc>] (SyS_close) from [<80107ce0>] (ret_fast_syscall+0x0/0x4c)
[ 2547.695051] nfs: server ease not responding, still trying
[ 2548.735626] nfs: server ease not responding, still trying
[ 2548.768826] nfs: server ease OK
[ 2548.796748] nfs: server ease OK
[ 2701.296329] INFO: task ld:24879 blocked for more than 120 seconds.
[ 2701.300214] Tainted: G C 4.14.31-1-ARCH #1
[ 2701.304061] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 2701.311642] ld D 0 24879 24804 0x00000000
[ 2701.315536] [<80a87848>] (__schedule) from [<80a88018>] (schedule+0x3c/0xa0)
[ 2701.319458] [<80a88018>] (schedule) from [<8015c138>] (io_schedule+0x14/0x3c)
[ 2701.323355] [<8015c138>] (io_schedule) from [<80230be4>] (wait_on_page_bit+0x110/0x15c)
[ 2701.330878] [<80230be4>] (wait_on_page_bit) from [<80230d0c>] (__filemap_fdatawait_range+0xdc/0x128)
[ 2701.338447] [<80230d0c>] (__filemap_fdatawait_range) from [<80233190>] (filemap_write_and_wait_range+0x54/0x88)
[ 2701.345916] [<80233190>] (filemap_write_and_wait_range) from [<803db1c4>] (nfs_file_fsync+0x30/0x280)
[ 2701.353469] [<803db1c4>] (nfs_file_fsync) from [<802d5dcc>] (vfs_fsync+0x24/0x2c)
[ 2701.360953] [<802d5dcc>] (vfs_fsync) from [<8029d758>] (filp_close+0x2c/0x80)
[ 2701.364740] [<8029d758>] (filp_close) from [<8029d7cc>] (SyS_close+0x20/0x48)
[ 2701.368593] [<8029d7cc>] (SyS_close) from [<80107ce0>] (ret_fast_syscall+0x0/0x4c)
[ 2772.976750] nfs: server ease not responding, still trying
[ 2774.331264] nfs: server ease OK
[ 2947.057892] INFO: task ld:24879 blocked for more than 120 seconds.
[ 2947.061907] Tainted: G C 4.14.31-1-ARCH #1
[ 2947.066031] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 2947.074107] ld D 0 24879 24804 0x00000000
[ 2947.078244] [<80a87848>] (__schedule) from [<80a88018>] (schedule+0x3c/0xa0)
[ 2947.081483] [<80a88018>] (schedule) from [<8015c138>] (io_schedule+0x14/0x3c)
[ 2947.084348] [<8015c138>] (io_schedule) from [<80230be4>] (wait_on_page_bit+0x110/0x15c)
[ 2947.090033] [<80230be4>] (wait_on_page_bit) from [<80230d0c>] (__filemap_fdatawait_range+0xdc/0x128)
[ 2947.095898] [<80230d0c>] (__filemap_fdatawait_range) from [<80233190>] (filemap_write_and_wait_range+0x54/0x88)
[ 2947.101751] [<80233190>] (filemap_write_and_wait_range) from [<803db1c4>] (nfs_file_fsync+0x30/0x280)
[ 2947.107513] [<803db1c4>] (nfs_file_fsync) from [<802d5dcc>] (vfs_fsync+0x24/0x2c)
[ 2947.113352] [<802d5dcc>] (vfs_fsync) from [<8029d758>] (filp_close+0x2c/0x80)
[ 2947.116350] [<8029d758>] (filp_close) from [<8029d7cc>] (SyS_close+0x20/0x48)
[ 2947.119289] [<8029d7cc>] (SyS_close) from [<80107ce0>] (ret_fast_syscall+0x0/0x4c)
[ 2998.258064] nfs: server ease not responding, still trying
[ 2999.352463] nfs: server ease OK
[ 3192.819075] INFO: task ld:24879 blocked for more than 120 seconds.
[ 3192.823185] Tainted: G C 4.14.31-1-ARCH #1
[ 3192.827330] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3192.835447] ld D 0 24879 24804 0x00000000
[ 3192.839604] [<80a87848>] (__schedule) from [<80a88018>] (schedule+0x3c/0xa0)
[ 3192.842832] [<80a88018>] (schedule) from [<8015c138>] (io_schedule+0x14/0x3c)
[ 3192.845750] [<8015c138>] (io_schedule) from [<80230be4>] (wait_on_page_bit+0x110/0x15c)
[ 3192.851476] [<80230be4>] (wait_on_page_bit) from [<80230d0c>] (__filemap_fdatawait_range+0xdc/0x128)
[ 3192.857318] [<80230d0c>] (__filemap_fdatawait_range) from [<80233190>] (filemap_write_and_wait_range+0x54/0x88)
[ 3192.863126] [<80233190>] (filemap_write_and_wait_range) from [<803db1c4>] (nfs_file_fsync+0x30/0x280)
[ 3192.868837] [<803db1c4>] (nfs_file_fsync) from [<802d5dcc>] (vfs_fsync+0x24/0x2c)
[ 3192.874594] [<802d5dcc>] (vfs_fsync) from [<8029d758>] (filp_close+0x2c/0x80)
[ 3192.877558] [<8029d758>] (filp_close) from [<8029d7cc>] (SyS_close+0x20/0x48)
[ 3192.880466] [<8029d7cc>] (SyS_close) from [<80107ce0>] (ret_fast_syscall+0x0/0x4c)
[ 3223.539141] nfs: server ease not responding, still trying
[ 3224.579687] nfs: server ease not responding, still trying
[ 3224.612015] nfs: server ease OK
[ 3224.626000] nfs: server ease OK
[ 3438.580109] INFO: task objcopy:24916 blocked for more than 120 seconds.
[ 3438.583905] Tainted: G C 4.14.31-1-ARCH #1
[ 3438.587697] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3438.595231] objcopy D 0 24916 24912 0x00000000
[ 3438.599109] [<80a87848>] (__schedule) from [<80a88018>] (schedule+0x3c/0xa0)
[ 3438.603019] [<80a88018>] (schedule) from [<8015c138>] (io_schedule+0x14/0x3c)
[ 3438.606896] [<8015c138>] (io_schedule) from [<80230be4>] (wait_on_page_bit+0x110/0x15c)
[ 3438.614435] [<80230be4>] (wait_on_page_bit) from [<80230d0c>] (__filemap_fdatawait_range+0xdc/0x128)
[ 3438.622018] [<80230d0c>] (__filemap_fdatawait_range) from [<80233190>] (filemap_write_and_wait_range+0x54/0x88)
[ 3438.629666] [<80233190>] (filemap_write_and_wait_range) from [<803db1c4>] (nfs_file_fsync+0x30/0x280)
[ 3438.637259] [<803db1c4>] (nfs_file_fsync) from [<802d5dcc>] (vfs_fsync+0x24/0x2c)
[ 3438.644894] [<802d5dcc>] (vfs_fsync) from [<8029d758>] (filp_close+0x2c/0x80)
[ 3438.648704] [<8029d758>] (filp_close) from [<8029d7cc>] (SyS_close+0x20/0x48)
[ 3438.652599] [<8029d7cc>] (SyS_close) from [<80107ce0>] (ret_fast_syscall+0x0/0x4c)
[ 3448.820081] nfs: server ease not responding, still trying
[ 3450.148878] nfs: server ease OK
[ 3674.100906] nfs: server ease not responding, still trying
[ 3675.141506] nfs: server ease not responding, still trying
[ 3675.174279] nfs: server ease OK
[ 3675.202048] nfs: server ease OK
[ 3807.221430] INFO: task objcopy:24916 blocked for more than 120 seconds.
[ 3807.225253] Tainted: G C 4.14.31-1-ARCH #1
[ 3807.229007] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3807.236459] objcopy D 0 24916 24912 0x00000000
[ 3807.240428] [<80a87848>] (__schedule) from [<80a88018>] (schedule+0x3c/0xa0)
[ 3807.244393] [<80a88018>] (schedule) from [<8015c138>] (io_schedule+0x14/0x3c)
[ 3807.248202] [<8015c138>] (io_schedule) from [<80230be4>] (wait_on_page_bit+0x110/0x15c)
[ 3807.255540] [<80230be4>] (wait_on_page_bit) from [<80230d0c>] (__filemap_fdatawait_range+0xdc/0x128)
[ 3807.263030] [<80230d0c>] (__filemap_fdatawait_range) from [<80233190>] (filemap_write_and_wait_range+0x54/0x88)
[ 3807.270494] [<80233190>] (filemap_write_and_wait_range) from [<803db1c4>] (nfs_file_fsync+0x30/0x280)
[ 3807.277992] [<803db1c4>] (nfs_file_fsync) from [<802d5dcc>] (vfs_fsync+0x24/0x2c)
[ 3807.285364] [<802d5dcc>] (vfs_fsync) from [<8029d758>] (filp_close+0x2c/0x80)
[ 3807.289292] [<8029d758>] (filp_close) from [<8029d7cc>] (SyS_close+0x20/0x48)
[ 3807.293169] [<8029d7cc>] (SyS_close) from [<80107ce0>] (ret_fast_syscall+0x0/0x4c)
[ 3899.381659] nfs: server ease not responding, still trying
[ 3900.422241] nfs: server ease not responding, still trying
[ 3900.461112] nfs: server ease OK
[ 3900.474540] nfs: server ease OK
[ 4011.372575] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead.
[ 4052.982250] INFO: task as:25088 blocked for more than 120 seconds.
[ 4052.986324] Tainted: G C 4.14.31-1-ARCH #1
[ 4052.990389] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 4052.998504] as D 0 25088 25086 0x00000000
[ 4053.002785] [<80a87848>] (__schedule) from [<80a88018>] (schedule+0x3c/0xa0)
[ 4053.006065] [<80a88018>] (schedule) from [<8015c138>] (io_schedule+0x14/0x3c)
[ 4053.008960] [<8015c138>] (io_schedule) from [<80230be4>] (wait_on_page_bit+0x110/0x15c)
[ 4053.014564] [<80230be4>] (wait_on_page_bit) from [<80230d0c>] (__filemap_fdatawait_range+0xdc/0x128)
[ 4053.020330] [<80230d0c>] (__filemap_fdatawait_range) from [<80233190>] (filemap_write_and_wait_range+0x54/0x88)
[ 4053.026110] [<80233190>] (filemap_write_and_wait_range) from [<803db1c4>] (nfs_file_fsync+0x30/0x280)
[ 4053.031705] [<803db1c4>] (nfs_file_fsync) from [<802d5dcc>] (vfs_fsync+0x24/0x2c)
[ 4053.037527] [<802d5dcc>] (vfs_fsync) from [<8029d758>] (filp_close+0x2c/0x80)
[ 4053.040507] [<8029d758>] (filp_close) from [<8029d7cc>] (SyS_close+0x20/0x48)
[ 4053.043431] [<8029d7cc>] (SyS_close) from [<80107ce0>] (ret_fast_syscall+0x0/0x4c)
[ 4134.902727] nfs: server ease not responding, still trying
[ 4135.997194] nfs: server ease OK
[ 4529.145918] nfs: server ease not responding, still trying
[ 4529.145923] nfs: server ease not responding, still trying
[ 4529.145940] nfs: server ease not responding, still trying
[ 4529.145978] nfs: server ease not responding, still trying
[ 4529.146011] nfs: server ease not responding, still trying
[ 4529.146028] nfs: server ease not responding, still trying
[ 4529.146044] nfs: server ease not responding, still trying
[ 4538.105971] nfs: server ease not responding, still trying
[ 4538.109131] nfs: server ease not responding, still trying
[ 4544.506128] INFO: task gcc:2854 blocked for more than 120 seconds.
[ 4544.509193] Tainted: G C 4.14.31-1-ARCH #1
[ 4544.512157] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 4544.517957] gcc D 0 2854 2852 0x00000000
[ 4544.520871] [<80a87848>] (__schedule) from [<80a88018>] (schedule+0x3c/0xa0)
[ 4544.523830] [<80a88018>] (schedule) from [<8015c138>] (io_schedule+0x14/0x3c)
[ 4544.526762] [<8015c138>] (io_schedule) from [<80230be4>] (wait_on_page_bit+0x110/0x15c)
[ 4544.530980] [<80230be4>] (wait_on_page_bit) from [<80230d0c>] (__filemap_fdatawait_range+0xdc/0x128)
[ 4544.534883] [<80230d0c>] (__filemap_fdatawait_range) from [<80233190>] (filemap_write_and_wait_range+0x54/0x88)
[ 4544.538880] [<80233190>] (filemap_write_and_wait_range) from [<803db1c4>] (nfs_file_fsync+0x30/0x280)
[ 4544.542873] [<803db1c4>] (nfs_file_fsync) from [<802d5dcc>] (vfs_fsync+0x24/0x2c)
[ 4544.546949] [<802d5dcc>] (vfs_fsync) from [<8029d758>] (filp_close+0x2c/0x80)
[ 4544.549173] [<8029d758>] (filp_close) from [<8029d7cc>] (SyS_close+0x20/0x48)
[ 4544.551445] [<8029d7cc>] (SyS_close) from [<80107ce0>] (ret_fast_syscall+0x0/0x4c)
[ 4571.406855] nfs: server ease OK
[ 4571.406996] nfs: server ease OK
[ 4571.407031] nfs: server ease OK
[ 4571.407691] nfs: server ease OK
[ 4571.407701] nfs: server ease OK
[ 4571.410844] nfs: server ease OK
[ 4571.410877] nfs: server ease OK
[ 4571.411761] nfs: server ease OK
[ 4571.411810] nfs: server ease OK
[ 4790.267644] INFO: task ld:7630 blocked for more than 120 seconds.
[ 4790.270597] Tainted: G C 4.14.31-1-ARCH #1
[ 4790.273588] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 4790.279563] ld D 0 7630 7628 0x00000000
[ 4790.282558] [<80a87848>] (__schedule) from [<80a88018>] (schedule+0x3c/0xa0)
[ 4790.285531] [<80a88018>] (schedule) from [<8015c138>] (io_schedule+0x14/0x3c)
[ 4790.288488] [<8015c138>] (io_schedule) from [<80230be4>] (wait_on_page_bit+0x110/0x15c)
[ 4790.294136] [<80230be4>] (wait_on_page_bit) from [<80230d0c>] (__filemap_fdatawait_range+0xdc/0x128)
[ 4790.299855] [<80230d0c>] (__filemap_fdatawait_range) from [<80233190>] (filemap_write_and_wait_range+0x54/0x88)
[ 4790.305556] [<80233190>] (filemap_write_and_wait_range) from [<803db1c4>] (nfs_file_fsync+0x30/0x280)
[ 4790.311366] [<803db1c4>] (nfs_file_fsync) from [<802d5dcc>] (vfs_fsync+0x24/0x2c)
[ 4790.317112] [<802d5dcc>] (vfs_fsync) from [<8029d758>] (filp_close+0x2c/0x80)
[ 4790.320380] [<8029d758>] (filp_close) from [<8029d7cc>] (SyS_close+0x20/0x48)
[ 4790.323699] [<8029d7cc>] (SyS_close) from [<80107ce0>] (ret_fast_syscall+0x0/0x4c)
[ 4790.330500] INFO: task ld:7636 blocked for more than 120 seconds.
[ 4790.334181] Tainted: G C 4.14.31-1-ARCH #1
[ 4790.338097] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 4790.346223] ld D 0 7636 7633 0x00000000
[ 4790.350304] [<80a87848>] (__schedule) from [<80a88018>] (schedule+0x3c/0xa0)
[ 4790.354463] [<80a88018>] (schedule) from [<8015c138>] (io_schedule+0x14/0x3c)
[ 4790.358593] [<8015c138>] (io_schedule) from [<80230be4>] (wait_on_page_bit+0x110/0x15c)
[ 4790.366494] [<80230be4>] (wait_on_page_bit) from [<80230d0c>] (__filemap_fdatawait_range+0xdc/0x128)
[ 4790.374744] [<80230d0c>] (__filemap_fdatawait_range) from [<80233190>] (filemap_write_and_wait_range+0x54/0x88)
[ 4790.383021] [<80233190>] (filemap_write_and_wait_range) from [<803db1c4>] (nfs_file_fsync+0x30/0x280)
[ 4790.391236] [<803db1c4>] (nfs_file_fsync) from [<802d5dcc>] (vfs_fsync+0x24/0x2c)
[ 4790.399371] [<802d5dcc>] (vfs_fsync) from [<8029d758>] (filp_close+0x2c/0x80)
[ 4790.403607] [<8029d758>] (filp_close) from [<8029d7cc>] (SyS_close+0x20/0x48)
[ 4790.407831] [<8029d7cc>] (SyS_close) from [<80107ce0>] (ret_fast_syscall+0x0/0x4c)
