Henryl
install OpenPlotter RPI v0.10.0 NOOBS
Thu Mar 29, 2018 5:00 pm
I have try to install OpenPlotter RPI v0.10.0 NOOBS on my new Raspberry Pi 3 Modell B
But no , When booting up my Pi 3 it hang on booting just a Rainbow screen and a lightning yellow bolt.
I have install Noobs Version:2.7.0 Its works OK.
(I have install Noobs Version:2.3.0 same as problems as OpenPlotter RPI v0.10.0 NOOBS)
How to install OpenPlotter on Noobs Version:2.7.0 ?
uilfut
Re: install OpenPlotter RPI v0.10.0 NOOBS
Thu Mar 29, 2018 7:49 pm
Do you have an older Pi you could set it up on first, then update?
Not an expert here, just assuming OpenPlotter hasn't been updated for Pi3B+ yet.
If you have a Pi3b or Pi2b etc, install it there first then
sudo apt-get update && sudo apt-get -y dist-upgrade
And then try it in Pi3B+
Good luck
Henryl
Sat Mar 31, 2018 8:14 am
No am a total noobie and I have only the pi3b.
Sat Mar 31, 2018 8:19 am
NoobS is an installer / chooser it is not an Operating System.
Therefore presume you are running Raspbian Stretch OS.
You may have more success following this blog:
https://sailoog.gitbooks.io/openplotter ... arted.html
RPi 4B 4GB (SSD Boot)..
Henryl
Sat Mar 31, 2018 6:33 pm
Sailoogs says "OpenPlotter v0.10.0 is not Raspberry 3B+ compatible"
Next v1.x.x will be a major revision with big changes, these are some of them:
Based on Raspbian Stretch
Full autopilot implementation (pypilot)
Moitessier HAT implementation
New and better Signal K implementation with a web dashboard to manage settings and plugins
So I have just to stand by
Sat Mar 31, 2018 6:48 pm
You stated you had a 3B ??????
