While that is true, if you are not objecting to 50/60 cycle EM radiation, you have just "moved the goal posts". In terms of radiated power, this is the greatest amount of *artificial* radiation you're going to be exposed to, except for lighting.
In the film I mentioned there was a guy who did what you mentioned concerning aluminum foil...W. H. Heydt wrote: ↑Wed Mar 28, 2018 6:36 pmWould please quote the post you're referring to? By itself, it is difficult or impossible to determine which comment you are referring to.
Radiation energy (significantly) depends on the frequency. Thus, 50 Hz should have a "slightly different" physical effect than 50.000.000.000 Hz of a wifi client. Additionally, the "amount" of the effect on the human body strongly relates to the absorption capability of a certain frequency by biological cells. Whereas the first is quite understood, the second isnt. Nevertheless, I can not see any reason to absolve wifi radiaton from influencing my health just because living between a set of wires and sockets in my home didnt kill me up to now.W. H. Heydt wrote: ↑Wed Mar 28, 2018 6:40 pmWhile that is true, if you are not objecting to 50/60 cycle EM radiation, you have just "moved the goal posts". In terms of radiated power, this is the greatest amount of *artificial* radiation you're going to be exposed to, except for lighting.
Really...I suggest starting with a good course in Physics.
I suspect, you are far more likely to be killed by the 50Hz mains power supply to your home than any number of WiFi gadgets you are likely to have at home. At least there is evidence of mains power killing people whereas there is none for WiFi waves.Nevertheless, I can not see any reason to absolve wifi radiaton from influencing my health just because living between a set of wires and sockets in my home didnt kill me up to now
One too many zeros.
λ = v/f
If it's an actual technical issue, the OP should be interested in measuring the radiation that surrounds them rather that focusing on a single low-powered device like the RPi. Anything else is a premature optimization. Like I said, the odds are pretty good that radiation in the visible spectrum is the main "threat". Anything towards the UV side is going to be the most dangerous, and anything down into IR and microwave (outside of an oven) is going to be a minor issue. The impact of radio waves will likely be negligible.
It would seem the rfkill command can be used to turn off WiFi and the Bluetooth devices. If the Pi is running headless, how do you turn off HDMI? Does reducing the clock speed reduce radiation? Is there anything else?
tvservice -o
sudo rfkill block all
