2bdkid
Boot hang after "random: crng init done"
Sun Mar 25, 2018 11:51 pm
I pulled branch rpi-4.9.y from www.github.com/raspberrypi/linux and cross compiled the bcmrpi3 target for arm64. I copied over the kernel and *.dtb files into the boot directory. I also copied bootcode.bin, *.dat, and *.elf from www.github.com/raspberrypi/firmware into /boot. When the system boots, it stops at "random: crng init done" and will not continue. I found some other articles saying it was a power issue or sd card issue, but I built the system on a second sd card and had the same results. I'm thinking it's a kernel issue so would anyone know which kernel to try next?
2bdkid
Re: Boot hang after "random: crng init done"
Wed Mar 28, 2018 3:29 am
Solution: press enter and the prompt appears.
Can't believe it took me this long...
tkninja
Thu Apr 05, 2018 9:07 pm
By the way, this happens to me, too. You don't have to press Enter to get the prompt, however: just enter in a command, if Raspian automatically logs you in.
SoNic67
Thu May 17, 2018 11:27 am
In my case, pressing enter key or any command does nothing. It just moves the text on the screen one line up.
Roken
Thu May 17, 2018 7:38 pm
I was getting this when experimenting with NFS boot - and it usually meant that the system couldn't find rootfs.
Check cmdline.txt
doomkin
Fri Aug 10, 2018 12:48 am
At boot, the kernel waits for mouse movements to initialize the random number generator.
Kernel messages on boot:
sudo dmesg | less
The problem:
kernel: random: crng init done
The solution:
sudo apt install haveged
sudo systemctl enable haveged
nana199685
Fri Dec 14, 2018 11:55 am
sudo dmesg | less
The problem:
The solution:
i meet the same problem that the screen stop at "random: crng init done"
i did modify my cmdline.txt before i reboot
but now i can't type any command you mentioned.
when i type something and press enter
it just wraps and happen nothing
i have check my power that was normal
please help me.QQ
PhilE
Fri Dec 14, 2018 2:08 pm
The fact that the message says "crng init done" suggests the fault is with something else it is trying to start afterwards. Try with "initcall_debug=1" on in cmdline.txt, and then see what the last few messages say.
You say:
Can you remember what you changed, and have you tried changing it back?
Tmpod
Thu Dec 27, 2018 10:32 am
I have the exact same problem. I'm using raspbian lite and I started getting a kernal panic saying that it could not mount root fs onto
unknown-block(179, 2)
. After some searching I found a stackoverflow post that suggested changing something in the cmdline.txt file. So I did. And now I'm getting this. I've tried setting
initcall_debug=1
and no more messages seem to appear. The boot still hangs on
crng init done
. Here's cmdfile.txt copied and pasted
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=27504eef-06 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait initcall_debug=1
(what u changed was that last 06 digit at the end of the root part, that was previously 02)
Thanks in advance
PhilE
Sun Dec 30, 2018 6:54 pm
Try using the old method for specifying a root fs, i.e. the name of the block device on which it appears:
... root=/dev/mmcblk0p2 ...
To get more debug output you probably also need to add something like "loglevel=8'.
rin67630
Tue Jan 08, 2019 4:13 pm
/quote]
Ugh! that seem a valid explanation: I am running headless and HAVE NO MOUSE NOR KEYBOARD.
Pluging a mouse releases the boot process. But that is'nt the purpose of a headless machine!
Installing haveged works!
terwik231
Fri Mar 29, 2019 4:10 pm
I have the same issue, how do you edit that cmdline.txt file? I can`t leave boot screen
Fri Mar 29, 2019 6:03 pm
You can edit cmdline.txt with your SDCard or USB device inserted into a Windows machine. Just DO NOT accept any requests where Windows will try to help you to reformat the drive - just say "NO!".
This is a hippy & doctor free zone.
Ty13r
Sat Apr 20, 2019 4:53 pm
Hello world,
i have the same trouble trying installing Kally on my PI 3 B+.
I change my cmdline.txt like this :
i use this img "kali-linux-2019.1-rpi3-nexmon-64" flashing buy "balenaEtcher" after being format by SD Card formatter.
My Sd card is : scanDisk Ultra 16GB micro SD HC1
I tryed to press enter / move my moose / nothing happened. I don't find anything working on internet.
Tks !
Return to “Linux Kernel”
