Luckyfish13
Python program doesn't run properly from terminal
Sun Mar 25, 2018 8:23 am
Hi, this is my first post on here but have been lurking around for a while and learnt a lot so thanks!
My program is taking values from the Arduino analog sensor via USB to the Pi 3 and outputting the bar on the screen. The screen is a 5" hdmi 800x480 and all the drivers are installed and work fine.
I know the function's long but it needs to be quick and responsive for the project.
The program runs fine when I open Python 3 from the menu and use F5 to run.
But the problem comes when I try to run it from the command line (or rc.local or crontab) the serial connection code detects nothing from the Arduino. I can see the TX light flashing on the arduino so I'm guessing some libraries/serial ports are only opened when Python 3 is open? Am I even close?
Here's the arduino code:
int a =0;
void setup() {
Serial.begin(9600);
void loop() {
  int sensor_value = analogRead(A0);
  int send_pi = map(sensor_value,760,1000,88,0);
  Serial.println(send_pi);
  delay(10);
And for the Pi (Python 3):
#setup screen first
import pygame
pygame.init()
screen = pygame.display.set_mode((800,480), pygame.NOFRAME)
pygame.mouse.set_cursor((8,8),(0,0),(0,0,0,0,0,0,0,0),(0,0,0,0,0,0,0,0))
import time
import math
import os
import serial
import re
BLACK=(0,0,0)
WHITE=(255,255,255)
YELLOW = (255,212,0)
ORANGE = (255,158,0)
RED = (255,25,0)
BLUE = (1,102,122)
GREY = (135,135,135)
GREEN=(0,235,65)
#variables to store current and previous sensor values from arduino
FuelPos=1
PrevFuel=0
clock = pygame.time.Clock()
#define font to use
myFont = pygame.font.SysFont("Times New Roman",92)
#setup USB connection with arduino
ser = serial.Serial('/dev/ttyACM0',9600)
#Draw function to draw bar to screen
def DrawFuel(f):
        FuelPos = f
        if FuelPos > PrevFuel:
                if FuelPos <= 31:
                        for i in range (PrevFuel,FuelPos):
                                j = i * 5
                                j = 458 - j
                                h=j+4
                                pygame.draw.line(screen,ORANGE,[760,j],[760,h],4)
                                pygame.draw.line(screen,ORANGE,[760,j],[730,j],5)
                                pygame.display.flip()
                                #4
                        #1
                elif 31 < FuelPos <= 48:
                        if PrevFuel <= 31:
                                for i in range(0,31):
                                        j=i*5
                                        j=458-j
                                        h=j+4
                                        pygame.draw.line(screen,BLUE,[760,j],[760,h],4)
                                        pygame.draw.line(screen,BLUE,[760,j],[730,j],5)
                                        #4
                                for i in range(31,FuelPos):
                                        j=i*5
                                        j=458-j
                                        k=i-40
                                        k=math.pow(1.12,k)
                                        k=730-k
                                        h=j+4
                                        pygame.draw.line(screen,BLUE,[760,j],[k,j],5)
                                        #4
                                #1
                        else:
                                for i in range(PrevFuel,FuelPos):
                                        j=i*5
                                        j=458-j
                                        k=i-40
                                        k=math.pow(1.12,k)
                                        k=730-k
                                        h=j+4
                                        #4
                                #3
                        #3
                elif 48 < FuelPos <= 65:
                        if PrevFuel <= 31 :
                                        j=i*5
                                        j=458-j
                                        h=j+4
                                        #4
                                        j=i*5
                                        j=458-j
                                        k=i-40
                                        k=math.pow(1.12,k)
                                        k = 730-k
                                        h=j+4
                                        #4
                                #1
                        else:
                                        j=i*5
                                        j=458-j
                                        k=i-40
                                        k=math.pow(1.12,k)
                                        k=730-k
                                        h=j+4
                                        #4
                                #3
                        #3
                elif 65 < FuelPos <= 78:
                        if PrevFuel <= 31:
                                        j=i*5
                                        j=458-j
                                        h=j+4
                                        #4
                                        j=i*5
                                        j=458-j
                                        k=i-40
                                        k=math.pow(1.12,k)
                                        k=730-k
                                        h=j+4
                                        #4
                                #1
                        else:
                                        j=i*5
                                        j=458-j
                                        k=i-40
                                        k=math.pow(1.12,k)
                                        k=730-k
                                        h=j+4
                                        #4
                                #3
                        #3
                elif 78 < FuelPos <= 88:
                        if PrevFuel <= 31:
                                        j=i*5
                                        j=458-j
                                        h=j+4
                                        #4
                                        j=i*5
                                        j=458-j
                                        k=i-40
                                        k=math.pow(1.12,k)
                                        k=730-k
                                        h=j+4
                                        #4
                                #1
                        else:
                                        j=i*5
                                        j=458-j
                                        k=i-40
                                        k=math.pow(1.12,k)
                                        k=730-k
                                        h=j+4
                                        #4
                                #3
                        #3
                #1
        elif FuelPos < PrevFuel:
                if FuelPos <= 30:
                        if PrevFuel <= 31:
                                for i in range(0,FuelPos):
                                        j=i*5
                                        j=458-j
                                        h=j+5
                                        #4
                                for i in range(FuelPos,PrevFuel):
                                        j=i*5
                                        j=458-j
                                        h=j+2
                                        pygame.draw.line(screen,BLACK,[760,j],[760,h],4)
                                        pygame.draw.line(screen,BLACK,[760,j],[730,j],4)
                                        #4
                                #1
                        elif 31 < PrevFuel <= 89:
                                        j=i*5
                                        j=458-j
                                        h=j+2
                                        pygame.draw.line(screen,ORANGE,[760,j],[730,j],4)
                                        #4
                                for i in range(FuelPos,31):
                                        j=i*5
                                        j=458-j
                                        h=j+2
                                        #4
                                for i in range(31,PrevFuel):
                                        j=i*5
                                        j=458-j
                                        k=i-40
                                        k=math.pow(1.12,k)
                                        k=730-k
                                        h=j+2
                                        pygame.draw.line(screen,BLACK,[760,j],[k,j],4)
                                        #4
                                #3
                        #1
                elif 30 < FuelPos < 88:
                                j=i*5
                                j=458-j
                                k=i-40
                                k=math.pow(1.12,k)
                                k=730-k
                                h=j+2
                                #4
                        #3
                #3
##################### RUN CODE START #########################
DrawFuel(88)
PrevFuel = 88
DrawFuel(0)
PrevFuel = 0
Fr = 1000
a = 0
run = True
while run:
    clock.tick(Fr)
    for event in pygame.event.get():
        if event.type == pygame.KEYUP and event.key == pygame.K_ESCAPE:
            run = False
    line=str(ser.readline()) #read USB connection from arduino
#extract the numbers from the serial string
    if len(line) == 8:
        a = int(line[2])
    elif len(line) == 9:
        b = int(line[2])
        b = b * 10
        c = int(line[3])
        a = b+c
#draw code
    pygame.draw.rect(screen,BLACK,[350,150,200,100])
    DispNo = myFont.render(str(a),1,WHITE)
    screen.blit(DispNo,[350,150])
    DrawFuel(a)
    PrevFuel = a
pygame.quit()
