vk4tec
Suggestions for LCD Please
Sun Mar 25, 2018 2:10 am
Hello
We track balloons and I would like a text style LCD to show
Identity
Latitude
Longitude
Distance
Direction
Lock ?
Suggestions for a Pi compatible HAT that would fit a Pi that can be programmed in Python or perl ?
Andy
Andrew Rich
email: [email protected]
http://www.tech-software.net/ ( hobby website )
http://59.167.159.165/ ( Raspberry Pi ADS-B server ) RTL SDR
W. H. Heydt
Re: Suggestions for LCD Please
Sun Mar 25, 2018 3:00 am
Take a look at the various displays Adafruit has. It depends on what you actually want. Do you just want a numeric display, e.g. a "seven segment" type or a dot-matrix, or do you want a general purpose display with enough resolution and area to show the data you want displayed? If it were me, I'd probably go with the RPF 7" display that connects to the DSI port. I'm assuming that this is to be used on the ground....
vk4tec
Sun Mar 25, 2018 4:02 am
That's what confuses me
How do you do characters on a graphics display ?
If it was character based it would have to be many lines
Andrew
Andrew Rich
W. H. Heydt
Sun Mar 25, 2018 4:22 am
Andrew
Easiest way is to display a terminal window and put your text in that. It has all the programming needed to do so....
