15:12:16.744 T:1944736320 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:12:16.744 T:1944736320 NOTICE: -----------------------------------------------------------------------
15:12:16.744 T:1944736320 NOTICE: Starting Kodi (17.6 Git:a9a7a20). Platform: Linux ARM 32-bit
15:12:16.744 T:1944736320 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
15:12:16.744 T:1944736320 NOTICE: Kodi compiled Apr 13 2018 by GCC 6.2.0 for Linux ARM 32-bit version 4.9.80 (264528)
15:12:16.744 T:1944736320 NOTICE: Running on LibreELEC (official): 8.2.5, kernel: Linux ARM 32-bit version 4.9.80
15:12:16.744 T:1944736320 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
15:12:16.744 T:1944736320 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
15:12:16.744 T:1944736320 NOTICE: ARM Features: Neon enabled
15:12:16.744 T:1944736320 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
15:12:16.744 T:1944736320 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
15:12:16.744 T:1944736320 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
15:12:16.745 T:1944736320 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
15:12:16.745 T:1944736320 NOTICE: special://envhome/ is mapped to: /storage
15:12:16.745 T:1944736320 NOTICE: special://home/ is mapped to: /storage/.kodi
15:12:16.745 T:1944736320 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
15:12:16.745 T:1944736320 NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
15:12:16.745 T:1944736320 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
15:12:16.745 T:1944736320 NOTICE: Local hostname: LibreELEC
15:12:16.745 T:1944736320 NOTICE: Log File is located: /storage/.kodi/temp//kodi.log
15:12:16.746 T:1944736320 NOTICE: -----------------------------------------------------------------------
15:12:16.913 T:1944736320 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
15:12:16.919 T:1944736320 NOTICE: load settings...
15:12:17.023 T:1944736320 NOTICE: Found 2 Lists of Devices
15:12:17.023 T:1944736320 NOTICE: Enumerated PI devices:
15:12:17.023 T:1944736320 NOTICE: Device 1
15:12:17.024 T:1944736320 NOTICE: m_deviceName : HDMI
15:12:17.024 T:1944736320 NOTICE: m_displayName : HDMI
15:12:17.024 T:1944736320 NOTICE: m_displayNameExtra:
15:12:17.024 T:1944736320 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:12:17.024 T:1944736320 NOTICE: m_channels : FL,FR
15:12:17.024 T:1944736320 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
15:12:17.024 T:1944736320 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
15:12:17.024 T:1944736320 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
15:12:17.024 T:1944736320 NOTICE: Device 2
15:12:17.024 T:1944736320 NOTICE: m_deviceName : Analogue
15:12:17.024 T:1944736320 NOTICE: m_displayName : Analogue
15:12:17.024 T:1944736320 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:12:17.024 T:1944736320 NOTICE: m_sampleRates : 48000
15:12:17.024 T:1944736320 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
15:12:17.024 T:1944736320 NOTICE: m_streamTypes : No passthrough capabilities
15:12:17.024 T:1944736320 NOTICE: Device 3
15:12:17.024 T:1944736320 NOTICE: m_deviceName : Both
15:12:17.024 T:1944736320 NOTICE: m_displayName : HDMI and Analogue
15:12:17.024 T:1944736320 NOTICE: Enumerated PULSE devices:
15:12:17.024 T:1944736320 NOTICE: Device 1
15:12:17.024 T:1944736320 NOTICE: m_deviceName : Default
15:12:17.024 T:1944736320 NOTICE: m_displayName : Default
15:12:17.024 T:1944736320 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
15:12:17.025 T:1944736320 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:12:17.025 T:1944736320 NOTICE: m_channels : FL,FR
15:12:17.025 T:1944736320 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
15:12:17.025 T:1944736320 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
15:12:17.025 T:1944736320 NOTICE: m_streamTypes : No passthrough capabilities
15:12:17.047 T:1944736320 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
15:12:17.047 T:1944736320 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<showexitbutton>false</showexitbutton>
<remotedelay>1</remotedelay>
<fanartres>720</fanartres>
<imageres>540</imageres>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
</advancedsettings>
15:12:17.049 T:1944736320 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:12:17.049 T:1944736320 NOTICE: Default Video Player: VideoPlayer
15:12:17.049 T:1944736320 NOTICE: Default Audio Player: paplayer
15:12:17.049 T:1944736320 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:12:17.049 T:1944736320 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:12:17.049 T:1944736320 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:12:17.051 T:1944736320 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:12:17.052 T:1944736320 NOTICE: Loaded playercorefactory configuration
15:12:17.052 T:1944736320 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:12:17.052 T:1944736320 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:12:17.168 T:1944736320 NOTICE: Running database version Addons27
15:12:17.335 T:1944736320 NOTICE: ADDONS: Using repository repository.kodi.game
15:12:17.335 T:1944736320 NOTICE: ADDONS: Using repository repository.libreelec.tv
15:12:17.335 T:1944736320 NOTICE: ADDONS: Using repository repository.xbmc.org
15:12:17.401 T:1944736320 NOTICE: Raspberry PI firmware version: Apr 6 2018 18:05:06
Copyright (c) 2012 Broadcom
version 6e5c0b2ea66e88157068fc38184b31a05a022892 (clean) (release)
15:12:17.401 T:1944736320 NOTICE: ARM mem: 768MB GPU mem: 256MB MPG2:0 WVC1:0
15:12:17.401 T:1944736320 NOTICE: cache.memorysize: 20MB libass.cache: 0MB
15:12:17.402 T:1944736320 NOTICE: Config:
arm_freq=1400
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x33e140
desired_osc_freq_boost=0x3c45b0
disable_commandline_tags=2
disable_l2cache=1
disable_splash=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
hdmi_ignore_cec_init=1
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=43750
over_voltage_avs_boost=0x23186
over_voltage_sdram_p=2
overscan_bottom=48
overscan_left=48
overscan_right=48
overscan_top=48
pause_burst_frames=1
program_serial_random=1
sdram_freq=500
sdram_schmoo=0x2000020
second_boot=1
device_tree=-
15:12:17.402 T:1944736320 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
15:12:17.404 T:1944736320 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 72.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 71.928070 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 75.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 60.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 59.940063 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 72.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 71.928070 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 800 x 600 for display 0 with 800 x 600 @ 75.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 60.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 59.940063 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 70.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 75.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1024 x 768 for display 0 with 1024 x 768 @ 120.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 60.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 59.940063 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1280 x 800 for display 0 with 1280 x 800 @ 120.000000 Hz
15:12:17.404 T:1944736320 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1280 x 1024 for display 0 with 1280 x 1024 @ 75.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1440 x 900 for display 0 with 1440 x 900 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1440 x 1080 for display 0 with 1600 x 1200 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1440 x 1080 for display 0 with 1600 x 1200 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
15:12:17.405 T:1944736320 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970032 Hz
15:12:17.405 T:1944736320 NOTICE: Found (1920x1080@60.000000) at 45, setting to RES_DESKTOP at 16
15:12:17.405 T:1944736320 NOTICE: Checking resolution 16
15:12:17.692 T:1944736320 NOTICE: GL_VENDOR = Broadcom
15:12:17.692 T:1944736320 NOTICE: GL_RENDERER = VideoCore IV HW
15:12:17.692 T:1944736320 NOTICE: GL_VERSION = OpenGL ES 2.0
15:12:17.692 T:1944736320 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
15:12:17.692 T:1944736320 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
18:31:46.288 T:1857024928 NOTICE: Running database version Addons27
18:31:46.292 T:1857024928 NOTICE: Running database version ViewModes6
18:31:47.433 T:1815081888 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
18:31:47.492 T:1857024928 NOTICE: Running database version Textures13
18:31:47.507 T:1857024928 NOTICE: Running database version MyMusic60
18:31:47.884 T:1857024928 NOTICE: Running database version MyVideos107
18:31:47.889 T:1857024928 NOTICE: Running database version TV29
18:31:47.892 T:1857024928 NOTICE: Running database version Epg11
18:31:47.894 T:1944736320 NOTICE: start dvd mediatype detection
18:31:48.508 T:1944736320 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
18:31:48.938 T:1944736320 NOTICE: initialize done
18:31:48.938 T:1944736320 NOTICE: Running the application...
18:31:48.981 T:1944736320 NOTICE: starting zeroconf publishing
18:31:48.984 T:1944736320 NOTICE: CWebServer[8080]: Started
18:31:48.984 T:1944736320 NOTICE: starting upnp client
18:31:48.999 T:1616032672 NOTICE: ES: Starting UDP Event server on port 9777
18:31:48.999 T:1616032672 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
18:31:50.080 T:1759507360 ERROR: GetDirectory - Error getting /storage/.kodi/temp/plugin.video.youtube/
18:31:50.299 T:1707570080 WARNING: CSkinInfo: failed to load skin settings
18:31:54.996 T:1732244384 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
18:31:55.531 T:1857024928 WARNING: Previous line repeats 1 times.
18:31:55.531 T:1857024928 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/v8lKB02kw35dZYDtMU9NXuF2Hdo.jpg
18:31:56.701 T:1565946784 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
18:31:59.437 T:1732244384 WARNING: Previous line repeats 1 times.
18:31:59.437 T:1732244384 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/vo7oOEv1Gn0iLMFwE0dqKO8phTW.jpg
18:32:01.438 T:1740632992 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
18:32:01.438 T:1740632992 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/4mFhm1yu1tsfIkm3zN7zvih9ydv.jpg
18:32:01.796 T:1565946784 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
18:32:01.796 T:1565946784 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/5aS0FqABU3fTDTVDkQfmOcnpuZb.jpg
18:32:03.900 T:1857024928 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
18:32:06.640 T:1857024928 WARNING: Previous line repeats 1 times.
18:32:06.641 T:1857024928 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/ApS9EHRwfiOU0OTvaMR3nUqCCOE.jpg
18:33:42.604 T:1944736320 NOTICE: Samba is idle. Closing the remaining connections
