Ibro100
Share Pi 3B as WiFi with OVS bridge not linux bridge
Thu Mar 22, 2018 6:13 am
Am stuck for three days for finding the solution but no result :?: :!: :!: :!: .
Going by following documentation on how to turn raspberry pi into access point.
https://www.raspberrypi.org/documentati ... s-point.md
https://thepi.io/how-to-use-your-raspbe ... ess-point/
https://github.com/SurferTim/documentat ... s-point.md
I was able to turn Raspberry pi successfully to share internet connection with my other devices without any hitches. However am running a project which involve openvswitch and sdn controller.
using bridge to access internet connection, in the above url valid documentations was written based on linux bridge stated below;
sudo apt-get install hostapd bridge-utils
sudo brctl addbr br0
sudo brctl addif br0 eth0
sudo nano /etc/network/interfaces
auto br0
iface br0 inet manual
bridge_ports eth0 wlan0
interface=wlan0
bridge=br0
#driver=nl80211
ssid=NameOfNetwork
hw_mode=g
however i have already
ovs-vsctl add br br0
ovs-vsctl add-port br0 eth0
running
ovs-vsctl show
I learnt that br0 and eth0 conflicting with ovs bridge and linux bridge.
How can i transform the above linux bridging descrisptions into ovs bridge and able to access internet by host devices?
Many thanks in advance
mukund.srinath
Re: Share Pi 3B as WiFi with OVS bridge not linux bridge
Tue Jul 03, 2018 6:22 pm
I am facing the same issue. Did you figure out a solution?
epoch1970
Tue Jul 03, 2018 7:48 pm
Does this help?
https://www.telematika.org/post/piovs-r ... n-vswitch/
(Warning: Pi running ubuntu.)
Ibro100
Mon Oct 08, 2018 7:26 pm
No. did you manage to solve that
Ibro100
Tue Nov 27, 2018 12:56 pm
did you manage to get it working?
