therealzsheley
.H264 Error when following the Parent Detector Tutorial
Tue Mar 20, 2018 6:01 pm
Hi! I am following the parent detector tutorial on the projects page. I have run into a problem however, every time I try to run the code python spits back a response similar to this:
.h264 not supported exceeds macroblocks limit
^ I summed that up I am not currently with the pi right now. If you want to see the code just tell me in a response and I will send it ASAP.
Re: .H264 Error when following the Parent Detector Tutorial
Tue Mar 20, 2018 6:36 pm
Sounds like a defective H264 file - can you tty a different one?
therealzsheley
Tue Mar 20, 2018 8:40 pm
That's the weird part no matter how I change the file it still gives me the same output. It's weird because it has never done that before in previous projects. (here is the tutorial I am following)---> https://projects.raspberrypi.org/en/pro ... detector/2
