stefant
Re: Ubuntu image for the new Raspberry Pi 3 B+
Thu Oct 04, 2018 11:19 am
Dear all,
This is a great Ubuntu 16.04 .img that works like a charm on my RPi 3b+ with one exception. I have a problem with connecting reliably to wifi via the built-in broadcom module. I make 2 hypothesis:
1. whether the driver (which, as I understand by reading this forum is a copy-paste from Raspbian), or
2. faulty hardware
Just to let you know that I've tested 2 more usb wifi dongles and they work out-of-the-box as expected (Odroid module 4 - Ralink RT5572 and the dongle that comes with an old RPi2 kit - Ralink RT5370).
My feeling is that it's a problem about the wifi card's drivers, namely brcmfmac43455-sdio* files from /lib/firmware/brcm/
Please can you guide towards other alternatives to these drivers, that can still work with the current Ubuntu 16.04? I'd like to test them.
AbelCS
Wed Oct 31, 2018 10:33 am
I've made a compatible Ubuntu Server 18.04 image for Raspberry Pi 3 B+ and I thought maybe it would be useful for you too, so I'm sharing it.
I don't have a hosting, so I've uploaded it to GitHub repo: https://github.com/AbelCS/ubuntu-server ... s/releases
If you have any question or problem, maybe I can help.
Regards!
thealy
Sun Nov 18, 2018 6:18 pm
Hi folks-
New here and searching for exactly what the original poster of this thread was looking for: Ubuntu 16.04 specifically to support ROS Kinetic on a Pi 3B+. I finally discovered that the generous people at Ubiquity Robotics have solved the problem it would appear.
https://downloads.ubiquityrobotics.com/pi.html
I downloaded the image, burned it, and it booted first try. The WiFi SSID is visible as documented, and after raking he leaves I'll press on from there. But certainly a breath of fresh air.
I hope this saves someone the pain I went through with a long list of failed attempts.
gilius
Fri Nov 23, 2018 7:12 am
Regards!
Thanks! I'm trying now... is it possible to update to full desktop version from there?
gilius
Fri Nov 23, 2018 2:03 pm
After upgrading to Ubuntu Desktop Internet no longer seems to be working and Firefox crashes the operating system.
AbelCS
Thu Nov 29, 2018 9:14 am
I haven't tried it yet. What errors are you getting?
code_exec
Thu Nov 29, 2018 7:13 pm
What desktop environment are you using? If you're using GNOME (ubuntu-desktop) then Ubuntu is going to be very slow. Try using a lighter desktop such as lubuntu-desktop or xubuntu-desktop. Also, can you try downloading the Raspberry Pi 3 WiFi firmware by following the instructions at https://wiki.ubuntu.com/ARM/RaspberryPi#WiFi
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
Cl4whammer
Mon Dec 03, 2018 5:47 pm
Regards!
i tried your image with my raspberry pi 3 b+ but iam having issues with the network. Everytime i reboot the network is gone. if i enter "netplan apply" into the bash network is working again. Do you have any ideas how to fix that?
Thanks!
manuti
Tue Dec 04, 2018 3:10 pm
Finally the official Ubuntu 18.04 Server image ready to burn and run ... http://cdimage.ubuntu.com/releases/18.04/beta/
more info in English https://www.mininodes.com/64-bit-ubuntu ... available/
and Spanish https://raspberryparatorpes.net/sistema ... erry-pi-3/
Raspberry para torpeshttp:/raspberryparatorpes.net
Cl4whammer
Wed Dec 05, 2018 5:09 pm
I do not get the network running with that too, here is my netplan config file:
network:
version: 2
renderer: networkd
ethernets:
eth0:
dhcp4: yes
AnandSN
Sun Dec 16, 2018 5:04 am
I am going to try this! Will update this post!
bikru
Wed Jan 02, 2019 5:22 am
Hi folks-
I just wanted to try this, but seems like the login password is not given.
Do you know what is the login password?
I have tried:
pi
raspberry
Bikram
DirkS
Wed Jan 02, 2019 11:09 am
Hi folks-
I have tried:
pi
raspberry
Bikram
On the Getting started section of the page you link to it says its user id/password is ubuntu/ubuntu
bikru
Wed Jan 02, 2019 5:31 pm
Thanks I will try it right now.
Bikram
midhunvnadh
Wed Jan 16, 2019 2:09 pm
I booted Ubuntu Mate on the Raspberry Pi 3 B+ :
Video Tutorial : https://youtu.be/J7xcd3I72Gw
Content Tutorial : http://spookycodes.com/2019/01/ubuntu-m ... rry-pi-3-b
Return to “Other”
