RaspISteve
So I Followed the Blog and Upgraded from Jessie to Stretch
Tue Mar 20, 2018 1:18 am
Guys,
As per thread title and it all sort of worked. However, when I do the routine "update" I get a lot of lines still referencing "jessie". The system does report its running "Stretch".
And before anyone tells me I should have simply re-started at the top with a new NOOBS... Didn't want to do that given the hard won stuff I had working on it and doing so perfectly happily. Also, had I known updating to "Stretch" would have lost me "EmulationStation" I wouldn't have done it.
What am I doing wrong?
Share and Enjoy.
Re: So I Followed the Blog and Upgraded from Jessie to Stretch
Tue Mar 20, 2018 6:15 am
Possibly you have extra repositories that still refer to Jessie.
Post the output of apt-cache policy That might give some clues.
RaspISteve
Wed Mar 21, 2018 10:21 pm
rpdom,
Yep. tried your suggestion.. see below.
pi@pi3b:~ $ sudo apt-cache policy
Package files:
 100 /var/lib/dpkg/status
     release a=now
 500 http://archive.raspberrypi.org/debian stretch/ui armhf Packages
     release o=Raspberry Pi Foundation,a=stable,n=stretch,l=Raspberry Pi Foundation,c=ui,b=armhf
     origin archive.raspberrypi.org
 500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
     release o=Raspberry Pi Foundation,a=stable,n=stretch,l=Raspberry Pi Foundation,c=main,b=armhf
 500 http://dl.bintray.com/pipplware/dists/jessie/armv7/binary ./ Packages
     release c=
     origin dl.bintray.com
 500 http://dl.bintray.com/pipplware/dists/jessie/main/binary ./ Packages
     release c=
 500 http://mirrordirector.raspbian.org/raspbian stretch/rpi armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=rpi,b=armhf
     origin mirrordirector.raspbian.org
 500 http://mirrordirector.raspbian.org/raspbian stretch/non-free armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=non-free,b=armhf
 500 http://mirrordirector.raspbian.org/raspbian stretch/contrib armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=contrib,b=armhf
 500 http://mirrordirector.raspbian.org/raspbian stretch/main armhf Packages
     release o=Raspbian,a=stable,n=stretch,l=Raspbian,c=main,b=armhf
Pinned packages:
I don't believe that I have done anything other than what was describe in the Blog. There were quite a number of line reports from the "update" option that included "jessie".
Quite where I go from here not sure. Perhaps I just rescue what I can, take the hit, and flush the SD and go for a new NOOBS.
Thanks for the input.
Share and Enjoy.
RaspISteve
Wed Mar 21, 2018 10:28 pm
Have just done "update" and got the following:
pi@pi3b:~ $ sudo apt-get update
Hit:1 http://archive.raspbian.org/raspbian stretch InRelease
Hit:2 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Get:3 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
Ign:4 http://dl.bintray.com/pipplware/dists/jessie/main/binary ./ InRelease
Ign:5 http://dl.bintray.com/pipplware/dists/jessie/armv7/binary ./ InRelease
Ign:6 http://dl.bintray.com/pipplware/dists/jessie/main/binary ./ Release
Ign:7 http://dl.bintray.com/pipplware/dists/jessie/armv7/binary ./ Release
Ign:8 http://dl.bintray.com/pipplware/dists/jessie/main/binary ./ Packages
Ign:9 http://dl.bintray.com/pipplware/dists/jessie/main/binary ./ Translation-en
Ign:10 http://dl.bintray.com/pipplware/dists/jessie/main/binary ./ Translation-en_GB
Ign:11 http://dl.bintray.com/pipplware/dists/jessie/armv7/binary ./ Packages
Ign:12 http://dl.bintray.com/pipplware/dists/jessie/armv7/binary ./ Translation-en
Ign:13 http://dl.bintray.com/pipplware/dists/jessie/armv7/binary ./ Translation-en_GB
Get:14 http://archive.raspberrypi.org/debian stretch/main Sources [48.3 kB]
Get:15 http://archive.raspberrypi.org/debian stretch/main armhf Packages [144 kB]
Err:8 http://dl.bintray.com/pipplware/dists/jessie/main/binary ./ Packages
  404  Not Found
Err:11 http://dl.bintray.com/pipplware/dists/jessie/armv7/binary ./ Packages
  404  Not Found
Fetched 217 kB in 3s (56.8 kB/s)
Reading package lists... Done
W: The repository 'http://dl.bintray.com/pipplware/dists/jessie/main/binary ./ Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: The repository 'http://dl.bintray.com/pipplware/dists/jessie/armv7/binary ./ Release' does not have a Release file.
E: Failed to fetch http://dl.bintray.com/pipplware/dists/jessie/main/binary/./Packages  404  Not Found
E: Failed to fetch http://dl.bintray.com/pipplware/dists/jessie/armv7/binary/./Packages  404  Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
pi@pi3b:~ $
Don't really understand this stuff. Hope it helps someone....
Share and Enjoy.
