boybanyas
C# WiringPi - unable to load libwiringPi.so
Mon Mar 19, 2018 11:29 am
This may be a simple problem, it's giving me headache for days already. Hope you could help out.
I have a working C# program using WiringPi last year. I'm using Visual Studio 2015.
Now I want to use it again, but it produces this error:
"Unable to load DLL 'libwiringPi.so'.
I'm using danriches WiringPi.net
Please see attach image file.
Thank you.
Patm
Re: C# WiringPi - unable to load libwiringPi.so
Thu Mar 22, 2018 3:44 am
First question - did you install wiringpi?
boybanyas
Thu Mar 22, 2018 7:12 am
Hi Patm,
Thanks for your response.
I followed https://gitlearning.wordpress.com/2016/ ... ts-with-c/
I build WiringPi wrapper class in Visual Studio, then add WiringPi.dll in references of my form.
If in case I miss something, can you please guide me. I forgot how I made it work last year.
What should be done to install libwiringPi.so in Visual Studio 2017?
Patm
Fri Mar 23, 2018 11:57 pm
Well I was just trying it out. The default package doesn't seem to even have a libwiringPi.o so I removed it and cloned wiringPi's git repository according to their instructions at http://wiringpi.com/download-and-install/
From there I went into the wiringPi directory and found all the .o files and, cc'd as per instructions (just the first one - the other two are no longer necessary apparently).
From there I compiled the wiringPi.net solution and copied the .exe and .dll to the pi and it didn't complain.
Patm
Sat Mar 24, 2018 12:44 pm
Just had a thought, are you running the program locally on your PC or from the command line on your Pi?
boybanyas
Sat Mar 24, 2018 11:34 pm
I'm currently developing the program from my PC (windows 10) using Visual Studio 2017.
Once I'm done, i will transfer the compiled exe program to the Raspberry pi.
I'm still on the first stage, I can't compile on VS because it cannot locate libwiringPi.so.
I will clone wiringPi's git repository using Raspberry Pi, get the libwiringPi.so and transfer (using filezilla) it to the /WiringPi/bin/debug folder on my PC.
Is this procedure correct?
boybanyas
Sun Mar 25, 2018 1:38 am
On raspberry, I did "cc -shared wiringPi.o -o libwiringPi.so" to create the libwiringPi.so.
Then transfer the created libwiringPi.so to C:windows/system32 folder.
No more unable to load libwiringPi.so error, but System.BadImageFormatException occurred. An attempt was made to load a program with an incorrect format.
Patm
Sun Mar 25, 2018 2:47 pm
I don't have wiringPi on the PC, don't think it exists except as a fake that gives you the ability to compile but the functions would be all empty.
What I did was create a samba share on the Pi and put the project there. I only load the project from the Pi. I can then use build (running doesn't work on the PC even if there's no errors since it doesn't have the devices) and run the binary with "mono my.exe:.
I then downloaded MonoRemoteDebugger and unzipped it to my Pi home directory and run that from a second CLI. Next get the MonoRemoteDebugger plugin for VS (2015 or 2017) and install that.
From there I can just choose the MonoRemoteDebugger->Debug Remote and it'll run on the Pi while reporting debug information on the PC. Just keep in mind you won't see build errors so run build from the PC (though the project you've got loaded is on the Pi) and once that's good do a Remote Debug.
Oh and if you mono my.exe it'll dump a stack trace into the CLI too - sometimes the debug information getting to the PC doesn't tell you enough.
boybanyas
Tue Mar 27, 2018 3:50 pm
Thanks Patm for the suggestions.
I remember before that I program directly on Visual Studio C#, then transfer the Release folder to the Raspberry Pi wherein I will execute it using Mono.
Maybe there are plugins I'm missing or need tweaks on the updated wiringPi.
marcc70
Mon Mar 11, 2019 3:27 pm
Hi There boybanyas,
Did you resolve this problem?
Because at the moment I am stuck with exactly the same problem as yours.
Would appreciate it if you have time to response.
Thanks and regards,
Marc
dobova86
Fri Mar 15, 2019 10:00 am
I'm working in C# too, but on NetCore 2.2 and I find Unosquare wrapper around the wiringPi lib working very nice.
https://github.com/unosquare/raspberryio
pdavis68
Sat Mar 23, 2019 10:03 pm
I'm confused. Is the OP talking about developing a C# .NET Framework app for Raspberry Pi? I don't think that'll work. You can do .NET Core, but you can't do .NET Framework.
Furthermore, if you're linking to wiringPi.so, you won't be able to build in windows. BadImageFormat because .so files aren't a recognized windows image format. Unfortunately, as far as I can tell, you can't actually build for arm in VS2017.
You'll need to switch to .net core (2.2 is just dandy) and you'll need to actually build on the Pi.
To make things easier, you can create your initial project and do the development in vs.net and copy it over with some minor changes. I haven't run into your issue because I'm not linking external libraries, so I can develop and compile in Windows and then just copy to the pi to rebuild.
You can download the sdk and runtime here:
https://dotnet.microsoft.com/download/t ... 2-binaries
(both from this page: https://dotnet.microsoft.com/download/dotnet-core/2.2)
