Thank you for taking the time to reply. In fact, it was your post (
viewtopic.php?f=29&t=196778) that prompted me to try this external hard drive with my early Pi 2B and Stretch.
It seems that I now need to use your usb-boot script to solve the problem I'm having. I was able to open the usb-boot.zip file using the "unzip" command, but now what?
1. How do I actually use usb-boot? Run as a bash script after making it executable with chmod? Then the run command would be?
2. When is the usb-boot script to be run? After plugging in both the SD card (with Stretch on it) and the USB hard drive?
3. Similar questions regarding the use of fix-rc.zip archive. How to use it and ...when? I'm very uncertain about how to use fix-rc and when it's to be run...right after first boot into Stretch? Before the first boot? Are the two solutions dealt with by fix-rc accomplished by running the script only once?
Sorry I need this degree of hand-holding, but I'm not very linux-savvy. However, a step-by-step description of how and when to use usb-boot and fix-rc scripts would likely be a welcome addition to your post (
viewtopic.php?f=29&t=196778) by other newbies too.
Anyway, thank you again for trying to help me get Stretch running reliably on the external hard drive. Your efforts are really appreciated.
