/// GestureDetection.cpp
/// Detects hand gestures and controls respective GPIO
/// Author: Sriram Emarose
/// Contact: sriram.emarose@gmail.com
#include <iostream>
#include <wiringPi.h>
#include "opencv2/objdetect/objdetect.hpp"
#include "opencv2/highgui/highgui.hpp"
#include "opencv2/imgproc/imgproc.hpp"
using namespace std;
using namespace cv;
void DetectGesture(cv::Mat frame);
int controlPin1 = 28; // Pin 38 in Rpi3
int controlPin2 =29; // Pin 40 in Rpi3
int main()
if(wiringPiSetup() == -1)
std::cout<<"Unable to setup GPIOs access \n";
return 1;
pinMode(controlPin1, OUTPUT);
pinMode(controlPin2, OUTPUT);
cv::Mat img;
cv::VideoCapture capture(0);
while(capture.isOpened())
capture >> img;
if(!img.empty())
DetectGesture(img);
cv::waitKey(1);
if(i == 27)
break;
return 0;
cv::Mat img, binary;
cvtColor(frame, img, CV_BGR2GRAY);
//thresholding
cv::threshold(img, binary, 35, 255, cv::THRESH_BINARY_INV);
//Contour storage
vector<vector<Point>> Contours;
vector<Vec4i> hierarchy;
//convex Hull storage
vector<vector<Point>> cnvxHull(Contours.size());
vector<vector<int>> cnvxHullsI(Contours.size());
vector<vector<Vec4i>> defects(Contours.size());
//morphological transformations
erode(binary, binary, getStructuringElement(MORPH_RECT, Size(3, 3)));
dilate(binary, binary, getStructuringElement(MORPH_RECT, Size(8, 8)));
//finding the contours required
findContours(binary, Contours, hierarchy, CV_RETR_CCOMP, CV_CHAIN_APPROX_NONE, Point(0, 0));
//finding the contour of largest area and storing its index
int biggestContour = 0;
int maxarea = 0;
for (int i = 0; i < Contours.size(); i++)
double currentArea = contourArea(Contours[i]);
if ( currentArea > maxarea)
maxarea = currentArea;
biggestContour = i;
convexhull(Contours[i], cnvxHull[i], false);
convexhull(Contours[i], cnvxHullsI[i], false);
if(cnvxHullsI[i].size() > 3 )
convexityDefects(Contours[i], cnvxHullsI[i], defects[i]);
std::vector<cv::Point> peakCount;
if (maxarea > 100){
/// Draw convexity Defects
for(int j=0; j<defects[biggestContour].size(); ++j)
const Vec4i& v = defects[biggestContour][j];
float depth = v[3] / 256;
if (depth > 10) //
int startidx = v[0];
Point ptStart(Contours[biggestContour][startidx]);
peakCount.push_back(ptStart);
int endidx = v[1];
Point ptEnd(Contours[biggestContour][endidx]);
int faridx = v[2];
Point ptFar(Contours[biggestContour][faridx]);
line(frame, ptStart, ptEnd, Scalar(0, 255, 0), 5);
line(frame, ptStart, ptFar, Scalar(0, 255, 0), 5);
line(frame, ptEnd, ptFar, Scalar(0, 255, 0), 5);
circle(frame, ptFar, 4, Scalar(255, 0, 0), 5);
circle(frame, ptStart, 6, Scalar(0, 0, 255), 5);
if(peakCount.size() > 4)
digitalWrite(controlPin1, 1);
else if(peakCount.size() == 4)
digitalWrite(controlPin2, 1);
digitalWrite(controlPin1, 0);
else
digitalWrite(controlPin2, 0);
cv::imshow("Live", frame);
}I am trying to get this gesture detection source code (opencv, C++) to work on my RPi, i don't understand how to get it to run..?
Kindly help me out.
Thanks,
