AJB2K3
MIPI DSI screen usability Help.
Sun Mar 18, 2018 9:15 am
Screen identification and use.
I have a screen from a Sony Experia J which i believe uses MIPI Dsi but is has this tiny connector.
Here is a scan of the back with the only identification numbers I can find.
Is there an adapter that will allow me to use this with the raspberry pi?
Back in the old days, we were smarter then the technology.
Nowadays technology makes us look like villages fools in front of the children!
aBUGSworstnightmare
Re: MIPI DSI screen usability Help.
Sun Mar 18, 2018 4:53 pm
1st no: there is no adapter
2nd no: DSI displays are currently not supported; only the official one can use DSI
AJB2K3
Mon Mar 19, 2018 5:27 pm
Thats a shame.
is there a connector/breakout board for the connection on the screen?
aBUGSworstnightmare
Tue Mar 20, 2018 6:16 am
Thats a shame.
O.K., the DSI firmware is closed source ... that might be a shame but hopefully changes soon (as some guys are working on this).
But why should it be a shame that no breakout board for a random display is available? In a DIY world you can design it yourself.
Anyhow, your display uses MIPI interface, and because MIPI is a high speed interface a 'traditional breakout board' will not work most likely due to signal integrity issues (trace length, trace impedance, ... just to name a few).
So, even with a working DSI interface most users will not be able to fire their screen up, because you will need a dedicated adapter for it (and this might not be existent due to the vast diversity of displays).
aBUGSworstnightmare
Tue Mar 20, 2018 6:18 am
out of curiosity: Do you have access to the data sheet of your display?
That's also a mandatory item ...
