rlm
3B+ Power LED regular flashing sequence, no Green activity LED [solved]
Sat Mar 17, 2018 6:34 pm
Hi all,
Short:
Regular and continuous sequence of red power LED flashes, no green activity LED.
Long:
Just tried powering up a 3B+ using three different wall plug PSUs (5v, 2 - 2.5a) and a Manson HCS-3202 bench PSU.
With all of them, the red power LED continuously goes through a sequence of four long and three short (might be 4 and 4, not sure) flashes.
The green activity LED never lights. These PSU's all properly power other Raspberry Pi 3's (and their LCD panels) that I have.
All PSU's have been checked against a meter and seem to be operating correctly (good V and A, within tolerance with dummy load).
I know from previous postings that a flashing power (red) LED is usually down to a problematic PSU. But those never refer to a regular sequence of flashes. Is this something new to the 3B+? I can't find any documentation on-line for it, if it is new.
In this case I don't think the issue is a problematic PSU, could be wrong but I don't think so.
Any ideas?
Re: 3B+ Power LED regular flashing sequence, no Green activity LED
Sun Mar 18, 2018 2:40 am
If the red LED flashes it's either a useless PSU or a useless cable between the PSU and you RPi3B+ (or both).
This is a doctor free zone.
davidcoton
Sun Mar 18, 2018 9:03 am
Have you measured the 5V supply at the Pi? (Measure carefully at the GPIO connector 5V and Ground pins (see here).
Even that may not be conclusive -- checking with an oscilloscope will spot shorter blips than a meter can detect.
Signature retired
HawaiianPi
Sun Mar 18, 2018 12:42 pm
Hi all,
Short:
That does sound like some kind of error code indicator. I've seen the green activity LED do that during certain errors with the µSD card, but I've never heard of that with the power LED. Hopefully one of our helpful RPF engineers will chime in and offer some insight.
Do you know the wire gauge used in your power cables? Many µUSB cables have too much resistance to deliver much more that 500mA (0.5A) without significant voltage drop (due to thin internal wires).
joan
Sun Mar 18, 2018 12:52 pm
Have you written a recent image (2018-03-13) of Raspbian to the SD card?
rlm
Sun Mar 18, 2018 9:07 pm
Thanks for the suggestion to try an updated O/S. It wasn't the O/S per se, but using a new micro SD card that did the trick. There is something odd with the SD cards I was using. Could read/write them and use to boot an RPi3, just not boot an RPi3B+. Using one of the new SD cards with an older version of the O/S also worked with the RPi3B+. All the SD cards I use are Cat10 and from reputable makers (Toshiba, SanDisk, etc.). Anyhoo all fixed now! :)
USB leads all checked out and within power loss tolerances.
GPIO ground, 5V and 3.3V pins all checked out.
Thanks again.
Burngate
Mon Mar 19, 2018 5:52 pm
It's interesting that the schematic for the 3B has the POWER OK "PWR" LED fed from an APX803-46SAG chip, and the signal goes to PWR_LOW_N. On the 3B+ schematic that chip isn't mentioned, instead we have it fed by a signal called STATUS_LED_R (the green LED is now fed by STATUS_LED_G)
EDIT: viewtopic.php?f=72&t=208381
wildfire
Mon Mar 19, 2018 6:56 pm
Curious, Which older version?
E8 85 A2 64 C9 64 81 94 64 81 95 64 89 84 89 96 A3
Still NF Shirls
posthuman_1000
Sat Apr 07, 2018 11:54 pm
Thanks again.
I've just come across this same issue with my new Pi 3+ - using a SanDisk Ultra 8g C10.
What card did you switch to? Sounds like I'm going to need to order a new one
mahjongg
Sun Apr 08, 2018 12:11 am
This is another thread about using software that is NOT compatible with the 3B+, the blue lightening symbol, and the pattern blinking LED"S are the signs that indicate this.
Its NOT normally a power issue, although as always, that may be a secondary problem.
Read the boot problem sticky:
posthuman_1000
Sun Apr 08, 2018 12:24 am
mahjongg wrote: This is another thread about using software that is NOT compatible with the 3B+
Yes, that's the more likely reason in my case, I should have made that connection myself as I already knew my software wasn't compatible. I'm an idiot. Thanks for helping me understand.
davidcoton
Re: 3B+ Power LED regular flashing sequence, no Green activity LED [solved]
Tue Apr 10, 2018 4:06 pm
If you have a working OS installed (up to date Raspbian Stretch), then the red LED is the power indicator and should be constantly ON. If not you probably have a power supply problem.
The green LED is the SDCard activity indicator which will have an apparently random pattern.
If your Pi is not booting, then the red LED may give a pattern indicating that the OS is too old for the Pi3B+.
Or the green LED may give a pattern that helps diagnose particular problems. The patterns are described here.
Signature retired
kevinjjames
Sun Jun 17, 2018 6:12 am
The below link gives info about which all SD Cards are supported.
https://elinux.org/RPi_SD_cards
Thanks,
Kevin
meltwater
Sun Jan 05, 2020 10:14 am
Had this with my RPi3 recently, I thought it was completely dead.
It looks like it was because I setup a new image on another SDCard. I suspect this updated the firmware because a previously working SDCard stopped working and I ended up with the flashing sequence when powered. It certainly wasn't a problem with the SDCard since several others which were working also ended up with the same result (and were fine on my other RPis).
After reading this thread I tried the recently written SDCard (Sept2019 image I think) and all booted nicely. I will try updating everything, since it would be annoying if I've lost the backwards compatibility on this particular RPi.
Shall update if I can get the older cards to work again.
______________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
My new book: goo.gl/dmVtsc
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
davidcoton
Sun Jan 05, 2020 11:47 am
... it would be annoying if I've lost the backwards compatibility on this particular RPi.
Backwards compatibility (new software on older hardware) has been very carefully maintained. The latest Raspbian Buster works on ALL versions of the Raspberry Pi.
What is not guaranteed (and not provided, because it is almost impossible) is forwards compatibility -- the ability to run older versions of Raspbian on newer hardware.
It is wise to ensure that the software download is of the generation (Wheezy/Jessie/Stretch/Buster) current when the hardware was released (or later), and that it is fully updated before being used on new hardware. A download of Buster will work well enough to be updated in situ.
In practice, it is best to keep everything updated and to do version upgrades soon after a new one is released. There are exceptions, particularly non-networked embedded systems that are hard to upgrade.
Signature retired
