PiGraham
Connecting to 5G Wi-Fi on 3B+ [SOLVED]
Sat Mar 17, 2018 5:09 pm
I have my Pi3B+ and I tried to connect to a 5GHz AP but I can't see it's SSID.
This is using a Raspbian SD card that was used in a P iB+ and I ran dist-upgrade before trasnfering the card.
That is:
sudo apt-get update
sudo apt-get dist-upgrade
It boots OK. The GUI WIFi utility doesn't list my 5GHz AP, only 2.4GHz.
I can list SSIDs and my 5GH\ AP is not listed. I can see it from my Win10 PC and my Android phone
sudo iwlist wlan0 scan | grep ESSID
iw list reports 5Ghz channels as disabled.
How do I enable them?
My first thought was region code for WiFi but that is set to UKwhich I think allows 5GHz.
Any suggestions?
pi@raspberrypi:~ $ iw list
Wiphy phy0
	max # scan SSIDs: 10
	max scan IEs length: 2048 bytes
	max # sched scan SSIDs: 16
	max # match sets: 16
	max # scan plans: 1
	max scan plan interval: -1
	max scan plan iterations: 0
	Retry short limit: 7
	Retry long limit: 4
	Coverage class: 0 (up to 0m)
	Device supports T-DLS.
	Supported Ciphers:
		* WEP40 (00-0f-ac:1)
		* WEP104 (00-0f-ac:5)
		* TKIP (00-0f-ac:2)
		* CCMP-128 (00-0f-ac:4)
		* CMAC (00-0f-ac:6)
	Available Antennas: TX 0 RX 0
	Supported interface modes:
		 * IBSS
		 * managed
		 * AP
		 * P2P-client
		 * P2P-GO
		 * P2P-device
	Band 1:
		Capabilities: 0x1062
			HT20/HT40
			Static SM Power Save
			RX HT20 SGI
			RX HT40 SGI
			No RX STBC
			Max AMSDU length: 3839 bytes
			DSSS/CCK HT40
		Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
		Minimum RX AMPDU time spacing: 16 usec (0x07)
		HT TX/RX MCS rate indexes supported: 0-7
		Bitrates (non-HT):
			* 1.0 Mbps
			* 2.0 Mbps (short preamble supported)
			* 5.5 Mbps (short preamble supported)
			* 11.0 Mbps (short preamble supported)
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 2412 MHz [1] (20.0 dBm)
			* 2417 MHz [2] (20.0 dBm)
			* 2422 MHz [3] (20.0 dBm)
			* 2427 MHz [4] (20.0 dBm)
			* 2432 MHz [5] (20.0 dBm)
			* 2437 MHz [6] (20.0 dBm)
			* 2442 MHz [7] (20.0 dBm)
			* 2447 MHz [8] (20.0 dBm)
			* 2452 MHz [9] (20.0 dBm)
			* 2457 MHz [10] (20.0 dBm)
			* 2462 MHz [11] (20.0 dBm)
			* 2467 MHz [12] (20.0 dBm)
			* 2472 MHz [13] (20.0 dBm)
			* 2484 MHz [14] (disabled)
	Band 2:
			HT20/HT40
			RX HT20 SGI
			RX HT40 SGI
			No RX STBC
			DSSS/CCK HT40
		VHT Capabilities (0x00001020):
			Max MPDU length: 3895
			Supported Channel Width: neither 160 nor 80+80
			short GI (80 MHz)
			SU Beamformee
		VHT RX MCS set:
			1 streams: MCS 0-9
			2 streams: not supported
			3 streams: not supported
			4 streams: not supported
			5 streams: not supported
			6 streams: not supported
			7 streams: not supported
			8 streams: not supported
		VHT RX highest supported: 0 Mbps
		VHT TX MCS set:
			1 streams: MCS 0-9
		VHT TX highest supported: 0 Mbps
		Bitrates (non-HT):
			* 6.0 Mbps
			* 9.0 Mbps
			* 12.0 Mbps
			* 18.0 Mbps
			* 24.0 Mbps
			* 36.0 Mbps
			* 48.0 Mbps
			* 54.0 Mbps
		Frequencies:
			* 5170 MHz [34] (disabled)
			* 5180 MHz [36] (20.0 dBm)
			* 5190 MHz [38] (disabled)
			* 5200 MHz [40] (20.0 dBm)
			* 5210 MHz [42] (disabled)
			* 5220 MHz [44] (20.0 dBm)
			* 5230 MHz [46] (disabled)
			* 5240 MHz [48] (20.0 dBm)
			* 5260 MHz [52] (20.0 dBm) (no IR, radar detection)
			* 5280 MHz [56] (20.0 dBm) (no IR, radar detection)
			* 5300 MHz [60] (20.0 dBm) (no IR, radar detection)
			* 5320 MHz [64] (20.0 dBm) (no IR, radar detection)
			* 5500 MHz [100] (20.0 dBm) (no IR, radar detection)
			* 5520 MHz [104] (20.0 dBm) (no IR, radar detection)
			* 5540 MHz [108] (20.0 dBm) (no IR, radar detection)
			* 5560 MHz [112] (20.0 dBm) (no IR, radar detection)
			* 5580 MHz [116] (20.0 dBm) (no IR, radar detection)
			* 5600 MHz [120] (20.0 dBm) (no IR, radar detection)
			* 5620 MHz [124] (20.0 dBm) (no IR, radar detection)
			* 5640 MHz [128] (20.0 dBm) (no IR, radar detection)
			* 5660 MHz [132] (20.0 dBm) (no IR, radar detection)
			* 5680 MHz [136] (20.0 dBm) (no IR, radar detection)
			* 5700 MHz [140] (20.0 dBm) (no IR, radar detection)
			* 5720 MHz [144] (disabled)
			* 5745 MHz [149] (disabled)
			* 5765 MHz [153] (disabled)
			* 5785 MHz [157] (disabled)
			* 5805 MHz [161] (disabled)
			* 5825 MHz [165] (disabled)
	Supported commands:
		 * new_interface
		 * set_interface
		 * new_key
		 * start_ap
		 * join_ibss
		 * set_pmksa
		 * del_pmksa
		 * flush_pmksa
		 * remain_on_channel
		 * frame
		 * set_channel
		 * tdls_oper
		 * start_sched_scan
		 * start_p2p_device
		 * crit_protocol_start
		 * crit_protocol_stop
		 * connect
		 * disconnect
	Supported TX frame types:
		 * managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
		 * P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
	Supported RX frame types:
		 * managed: 0x40 0xd0
		 * P2P-client: 0x40 0xd0
		 * P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
		 * P2P-device: 0x40 0xd0
	software interface modes (can always be added):
	valid interface combinations:
		 * #{ managed } <= 1, #{ P2P-device } <= 1, #{ P2P-client, P2P-GO } <= 1,
		   total <= 3, #channels <= 1
		 * #{ managed } <= 1, #{ AP } <= 1, #{ P2P-client } <= 1, #{ P2P-device } <= 1,
		   total <= 4, #channels <= 1
	Device supports scan flush.
PiGraham
Re: Connecting to 5G Wi-Fi on 3B+
Sat Mar 17, 2018 6:14 pm
Maybe this should be in the Raspbian topic?
From there I see some pertinent comments so I tried this:
pi@raspberrypi:~ $ iw reg get
global
country GB: DFS-ETSI
	(2402 - 2482 @ 40), (N/A, 20), (N/A)
	(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW
	(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW
	(5490 - 5710 @ 160), (N/A, 27), (0 ms), DFS
	(57000 - 66000 @ 2160), (N/A, 40), (N/A)
Seems OK.
PiGraham
Re: Connecting to 5G Wi-Fi on 3B+ [SOLVED]
Sat Mar 17, 2018 6:29 pm
I restarted the interface and someone's 5G AP showed up! Just reboot after setting Wi-Fi region?
My own AP still wasn't showing up but seeing that now I had some 5GHz channels showing as enabled but some not I checked the channel the AP was using and it was not an enabled one. I guess the region of the AP was wrong.
Changes that and it works now.
