I live in Australia, so this may be only here, but my Pi3b came in a box and inside there was an antistatic bag.
Yes, I was. And I'm a little concerned that the Pi 3B+ seems to run a lot hotter than any of my other Pi's so wondered if it could have been damaged by electrostatic discharge. Even the USB and ethernet sockets are fairly warm where the ones on my other Pis are not at all. However, it seems to be running OK at the moment. All the other Pis I have, ~16, all came in ant-static bags all the way back to the original Pi 1.royhenderson wrote: ↑Fri Mar 16, 2018 9:13 pmAnyone else a little surprised that the 3B+ does not come in an anti-static bag?
Probably not (note the Element 14 logo on my Pi paper bag)... Also note the anti-static logo.
So far all my Pi computers--shipped to the States and Canada--have come in plastic antistatic bags. Given the tendency to rain, maybe there is less static electricity in the UK so antistatic bags aren't needed. Either that, or the paper is actually a new type of earth-friendly biodegradable antistatic bag. Maybe they only look like paper but are really made out of corn.
I think the Pi3B+ does seem to run a bit hotter because of the design which distributes heat away from the SoC to the rest of the PCB. So the heat is not isolated on the SoC, this is how the design has been able to achieve better thermal operation.MrEngman wrote: ↑Sat Mar 17, 2018 12:35 amYes, I was. And I'm a little concerned that the Pi 3B+ seems to run a lot hotter than any of my other Pi's so wondered if it could have been damaged by electrostatic discharge. Even the USB and ethernet sockets are fairly warm where the ones on my other Pis are not at all. However, it seems to be running OK at the moment. All the other Pis I have, ~16, all came in ant-static bags all the way back to the original Pi 1.
Did it come in the bag in a Pi box or just the bag?
Its there own postal box , no pi box like you get from element 14 or RS
(i.e. the box you mention is the large brown packaging box or a Pi box itself?
Thank you for the anecdote. Goes to show how hard it is to kill a Pi. About the only ways to do that I've seen mentioned much are significant overvoltage (e.g. 12v) or some months long immersion in salt water (the lost HAB that got returned), and even then I'm not sure it couldn't have been gotten back into work order, albeit with a lot of work.eupton wrote: ↑Sat Mar 17, 2018 4:23 pmThe boxes that we pack Raspberry Pi 3B+ (and recent units of earlier models) into at Sony contain conductive card which have the same effect as an anti-static bag. In practice I suspect it's overkill: I remember back in the day (2010) testing BCM2763 (BCM2835 but in a 9x9mm 0.4mm-pitch package with 128MB of RAM) units with the static gun and not being able to kill them until we turned the PCB itself black through repeated discharges.
Same here, though I actually ordered it late on the 14th, too late to ship that day. Arrived with the rest of the mail today. The one interesting thing about the box that I noticed that no one had mentioned so far is that it has a tab on one end with a hole for hanging it on a hook, as is done with many products in stores. Since I want at least a couple more Pi3B+ boards, I'll have to make sure to get at least one from Alled to see if they're doing their packaging differently.HawaiianPi wrote: ↑Sat Mar 17, 2018 9:17 pmJust received my 3B+ and was also surprised to find it loose in a much more flimsy tear open box. It was just sitting on a white card on top of the safety instructions and quick start guide. So that must be the conductive card, and the guide did provide a little cushion (at least in one direction). Bottom line is my new Pi3B+ survived its journey intact and booted right up (using the same PSU and µUSB cable that ran my old Pi3B).
Ordered from Newark/Element 14 on the 15th, shipped the same day (US Priority Mail) and received on the 17th.![]()
