Hmm, an improvement I overlooked.rpiMike wrote: ↑Thu Mar 15, 2018 10:43 pmSome info here, including thermal images:
https://medium.com/@ghalfacree/benchmar ... 122cf3d806
Ah very informative thermal images.rpiMike wrote: ↑Thu Mar 15, 2018 10:43 pmSome info here, including thermal images:
That's an interesting comparison of Pi computers, especially the heat dissipation analysis. The Linpack Mflop numbers are surprisingly low. A Pi 3B when configured correctly gets more than 6000 double-precision Mflops when running at 1200MHz, but the graph shows about 200 Mflops, which is a factor of 30 times too slow. When running benchmarks, it is important to compare new with previously established results.
Same with Gigabit Ethernet numbers but my favourite is the Wi-Fi 'Benchmark'. Neither bandwidth nor latency are benchmarked but 'signal quality' (and labeling channels as cells, claiming RPi 3 wouldn't be able to use channels 9 to 13 and that 3 B+ being able to use those would be related to 5GHz is plain weird).
I think you are probably going to have to reduce your sarcastic comments a bit please. Attacking others work is frowned upon here.tkaiser wrote: ↑Fri Mar 16, 2018 8:39 amSame with Gigabit Ethernet numbers but my favourite is the Wi-Fi 'Benchmark'. Neither bandwidth nor latency are benchmarked but 'signal quality' (and labeling channels as cells, claiming RPi 3 wouldn't be able to use channels 9 to 13 and that 3 B+ being able to use those would be related to 5GHz is plain weird).
Funny 'benchmarking gone wrong' example![]()
I think its too early to tell. We haven't testing every single heatsink combination possible, so cannot comment on specifics.rainer.brito wrote: ↑Fri Mar 16, 2018 12:26 pmGreat!
So, generally speaking, a Pi 3 B+ without heatsink still cooler than an aluminium heatsinked Pi 3B?
If the heatsink is a small and sticks onto the SoC then I'd expect the Pi3+ to be much more effective.rainer.brito wrote: ↑Fri Mar 16, 2018 12:26 pmSo, generally speaking, a Pi 3 B+ without heatsink still cooler than an aluminium heatsinked Pi 3B?
Is there a crossection through this arrangement available somewhere? I have hard time visualising it - it sounds like any external heatsink effectiveness would be severely diminished. Is the chip flat on the PCB or flat on the metal plate visible from the outside?the main trick is that they have flipped the chip (SoC) upside down, the back of the chip is completely flat and can make excellent thermal contact with the heat spreader that is mounted directly to it, the heat spreader in turn is thermally attached to the ground plane of the PI, so that heat is transferred to all corners of the PI. This much better thermal arrangement makes that the chip isn't such a hot spot as it was before.
And good thermal contact with the heat spreader too by the looks of it.gregeric wrote: ↑Fri Mar 16, 2018 6:21 pmSee https://en.wikipedia.org/wiki/Flip_chip
On the original 2837, the silicon faced upwards with tiny bond wires to connect to the outside world. Now it's been flipped over and, as per that wiki, bond wires done away with. Instead a more or less direct electrical & thermal connection to the PCB.
wget https://raw.githubusercontent.com/ssvb/cpuburn-arm/master/cpuburn-a53.S
gcc -o cpuburn-a53 cpuburn-a53.S
./cpuburn-a53
600 MHz is 'frequency capping' (both clockspeed and supply voltage to the ARM cores was reduced). Curious: while you run cpuburn can you please run in another shell
perl -e "printf \"%19b\n\", $(vcgencmd get_throttled | cut -f2 -d=)"
vcgencmd measure_volts | cut -f2 -d= | sed 's/000//'Code: Select all
#!/bin/bash
echo -e "To stop simply press [ctrl]-[c]\n"
Counter=14
DisplayHeader="Time Temp CPU fake/real Health state Vcore"
while true ; do
let Counter++
if [ ${Counter} -eq 15 ]; then
echo -e "${DisplayHeader}"
Counter=0
fi
Health=$(perl -e "printf \"%19b\n\", $(vcgencmd get_throttled | cut -f2 -d=)")
Temp=$(vcgencmd measure_temp | cut -f2 -d=)
RealClockspeed=$(vcgencmd measure_clock arm | awk -F"=" '{printf ("%0.0f",$2/1000000); }' )
SysFSClockspeed=$(awk '{printf ("%0.0f",$1/1000); }' </sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq)
CoreVoltage=$(vcgencmd measure_volts | cut -f2 -d= | sed 's/000//')
echo -e "$(date "+%H:%M:%S"): ${Temp}$(printf "%5s" ${SysFSClockspeed})/$(printf "%4s" ${RealClockspeed}) MHz $(printf "%019d" ${Health}) ${CoreVoltage}"
sleep 5
doneCode: Select all
pi@pi3:~ $ ./pistat.sh
16:21:17: 66.6'C 1400/1400 MHz 0000000000000000000 1.3625V
16:21:22: 66.6'C 1400/1400 MHz 0000000000000000000 1.3625V
16:21:27: 66.6'C 1400/1400 MHz 0000000000000000000 1.3625V
16:21:33: 65.5'C 1400/1400 MHz 0000000000000000000 1.3625V
16:21:38: 65.5'C 1400/1400 MHz 0000000000000000000 1.3625V
Nice, so it works. And the 1.4GHz DVFS OPP uses 1.3625V. With my Pi 3 I've seen either 1.3312V or 1.3250V at 1.2GHz and once frequency capping happened (cpufreq down to 600 MHz) it was 1.2V instead. I would assume if 1.4GHz uses 1.3625V then the 1.2GHz OPP most probably shows a lower voltage as on the Pi 3.jahboater wrote: ↑Sat Mar 17, 2018 4:18 pmThis is your script while running the large build (make -j5):Code: Select all
pi@pi3:~ $ ./pistat.sh To stop simply press [ctrl]-[c] Time Temp CPU fake/real Health state Vcore 16:21:17: 66.6'C 1400/1400 MHz 0000000000000000000 1.3625V 16:21:22: 66.6'C 1400/1400 MHz 0000000000000000000 1.3625V 16:21:27: 66.6'C 1400/1400 MHz 0000000000000000000 1.3625V 16:21:33: 65.5'C 1400/1400 MHz 0000000000000000000 1.3625V 16:21:38: 65.5'C 1400/1400 MHz 0000000000000000000 1.3625V
1110000000000000010
||| |||_ under-voltage
||| ||_ currently throttled
||| |_ arm frequency capped
|||_ under-voltage has occurred since last reboot
||_ throttling has occurred since last reboot
|_ arm frequency capped has occurred since last rebootCode: Select all
19:45:51: 57.5'C 1400/1400 MHz 0000000000000000000 1.3500V
19:45:56: 60.7'C 1400/1400 MHz 0000000000000000000 1.3563V
19:46:01: 62.8'C 1400/1400 MHz 0000000000000000000 1.3563V
19:46:06: 64.5'C 1400/1400 MHz 0000000000000000000 1.3563V
19:46:11: 66.6'C 1400/1400 MHz 0000000000000000000 1.3625V
19:46:17: 67.7'C 1400/1400 MHz 0000000000000000000 1.3625V
19:46:22: 69.8'C 1400/1400 MHz 0000000000000000000 1.3625V
19:46:27: 70.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:46:33: 69.8'C 1400/1400 MHz 0000000000000000000 1.3625V
19:46:38: 69.8'C 1400/1400 MHz 0000000000000000000 1.3625V
19:46:43: 70.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:46:49: 70.9'C 1400/1200 MHz 0000000000000000000 1.2438V
19:46:54: 70.9'C 1400/1200 MHz 0000000000000000000 1.2438V
19:46:59: 70.9'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:04: 70.9'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:10: 72.0'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:15: 72.0'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:20: 72.0'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:26: 73.1'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:31: 73.1'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:36: 73.6'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:42: 73.6'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:47: 74.1'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:52: 74.1'C 1400/1200 MHz 0000000000000000000 1.2438V
19:47:57: 74.1'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:03: 74.7'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:08: 75.8'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:13: 76.3'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:19: 76.3'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:24: 76.3'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:29: 76.8'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:35: 77.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:40: 77.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:45: 77.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:51: 77.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:48:56: 77.9'C 1400/1200 MHz 0000000000000000000 1.2438V
19:49:01: 77.9'C 1400/1200 MHz 0000000000000000000 1.2438V
19:49:07: 78.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:49:12: 78.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:49:17: 78.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:49:23: 78.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:49:28: 78.4'C 1400/1200 MHz 0000000000000000000 1.2438V
19:49:33: 79.5'C 1400/1200 MHz 0000000000000000000 1.2438V
19:49:38: 79.5'C 1400/1200 MHz 0000000000000000000 1.2438V
19:49:44: 79.5'C 1400/1200 MHz 0000000000000000000 1.2438V
19:49:49: 79.5'C 1400/1200 MHz 0100000000000000000 1.2438V
19:49:54: 80.1'C 1400/1195 MHz 0100000000000000010 1.2438V
19:50:00: 79.5'C 1400/1195 MHz 0100000000000000000 1.2438V
19:50:05: 79.5'C 1400/1195 MHz 0100000000000000010 1.2438V
19:50:10: 80.1'C 1400/1141 MHz 0100000000000000000 1.2438V
19:50:16: 80.1'C 1400/1200 MHz 0100000000000000010 1.2438V
19:50:21: 80.6'C 1400/1195 MHz 0100000000000000010 1.2438V
19:50:26: 80.1'C 1400/1141 MHz 0100000000000000010 1.2438V
19:50:32: 80.6'C 1400/1195 MHz 0100000000000000010 1.2438V
19:50:37: 80.1'C 1400/1195 MHz 0100000000000000010 1.2438V
19:50:42: 80.6'C 1400/1195 MHz 0100000000000000010 1.2438V
19:50:48: 80.6'C 1400/1141 MHz 0100000000000000010 1.2438V
19:50:53: 80.1'C 1400/1141 MHz 0100000000000000010 1.2438V
19:50:58: 80.6'C 1400/1195 MHz 0100000000000000010 1.2438V
19:51:03: 80.1'C 1400/1141 MHz 0100000000000000010 1.2438V
19:51:09: 80.6'C 1400/1141 MHz 0100000000000000010 1.2438V
20:00:50: 38.6'C 600/ 600 MHz 0100000000000000000 1.2V
20:00:55: 39.2'C 600/ 600 MHz 0100000000000000000 1.2V
20:01:00: 39.2'C 600/ 600 MHz 0100000000000000000 1.2V
20:01:05: 39.2'C 600/ 600 MHz 0100000000000000000 1.2V
20:01:10: 39.2'C 600/ 600 MHz 0100000000000000000 1.2V
Thank you. So as expected the 1.2GHz DVFS OPP with RPi 3 B+ shows a lower voltage compared to the RPi 3 and it's still the same shit show with faked cpufreq values reported by the kernel on RPi. If you don't query ThreadX running on the main CPU (VC4) you have no idea what's happening.jahboater wrote: ↑Sat Mar 17, 2018 7:56 pmWow - the full GCC build on the Pi3+ took 4.6 hours! down from 5.3 hours for the Pi3.
I ran your stat program at the same time as cpuburn53 :-Code: Select all
Time Temp CPU fake/real Health state Vcore ... 19:46:27: 70.4'C 1400/1200 MHz 0000000000000000000 1.2438V
