Ivan219
Error of using cocos2d python 3.5
Thu Mar 15, 2018 4:18 pm
Hello, I have problem with use of the cocos2d on python 3.5
I install cocos2d with pip3. Cocos2d successfully installed.
I tried to start program:
https://github.com/CoderDojoLu/cocos2d- ... loWorld.py
But I got:
Cannot import cocos. Did you run 'pip install cocos2d' ?
  File "/home/pi/Desktop/test.py", line 7, in <module>
    class HelloWorld(cocos.layer.Layer):
NameError: name 'cocos' is not defined
How I can resolve problem?
KLL
Re: Error of using cocos2d python 3.5
Fri Mar 16, 2018 3:00 am
hi Ivan,
bad style, just missing the main required info,
but i was able to get the same error:
pi@RPI3:~/projects/cocos $ python helloWorld.py
  File "helloWorld.py", line 10, in <module>
when i started with python .. === python2x
but not installed with pip
( like you i used pip3 so must start with python3 )
pi@RPI3:~/projects/cocos $ pip3 install cocos2d
Collecting cocos2d
  Downloading https://www.piwheels.org/simple/cocos2d/cocos2d-0.6.5-py3-none-any.whl (288kB)
    100% |████████████████████████████████| 296kB 651kB/s
Collecting six>=1.4 (from cocos2d)
  Downloading six-1.11.0-py2.py3-none-any.whl
Collecting pyglet>=1.2 (from cocos2d)
  Downloading pyglet-1.3.1-py2.py3-none-any.whl (1.0MB)
    100% |████████████████████████████████| 1.0MB 274kB/s
Collecting future (from pyglet>=1.2->cocos2d)
  Downloading https://www.piwheels.org/simple/future/future-0.16.0-py3-none-any.whl (489kB)
    100% |████████████████████████████████| 491kB 309kB/s
Installing collected packages: six, future, pyglet, cocos2d
Successfully installed cocos2d-0.6.5 future-0.16.0 pyglet-1.3.1 six-1.11.0
so you miss to show the
- - install line
- - start line
beginning with IDLE3 can help
anyhow possibly better to do the full install like here
start with download zip file ...
what includes docs and samples.
Ivan219
Fri Mar 16, 2018 12:22 pm
Thank for your answer. I tried to do this steps again:
pi@raspberrypi:~ $ cd Desktop
pi@raspberrypi:~/Desktop $ pip3 install cocos2d
Collecting cocos2d
  Using cached six-1.11.0-py2.py3-none-any.whl
  Using cached pyglet-1.3.1-py2.py3-none-any.whl
pi@raspberrypi:~/Desktop $ python3 test.py
  File "test.py", line 7, in <module>
But the error still remains.
KLL
Fri Mar 16, 2018 12:38 pm
not look good,
sorry when i created that error by using "python" instead "python3" the error talk about
LINE 10
but you report:
hm, pls. post your file test.py
just make sure, is your system updated?
Ivan219
Fri Mar 16, 2018 12:44 pm
try:
	import cocos
except:
	print('Cannot import cocos. Did you run \'pip install cocos2d\' ?')
# define a simple HelloWorld() class that inherits from cocos.layer.Layer (making it a sub-class of it)
	# __init__ is run every time you instantiate the class
	def __init__(self):
		# Always call super in the constructor
		super(HelloWorld, self).__init__()
		# label will become an object with all the necessary to display a text, with font TimesNewRoman and it will be center-anchored
		# Note: .Label is a subclass of CocosNode
		label = cocos.text.Label('Hello, world', font_name='Times New Roman', font_size=32, anchor_x='center', anchor_y='center')
		# set the position of our text to x:320 y:240
		label.position = (320, 240)
		# add our label as a child. It is a CocosNode object, which know how to render themselves.
		self.add(label)
# our main function
def main():
	# We initialize the director, that takes care of our main window
	cocos.director.director.init()
	# We instantiate hello_layer with our HelloWorld() class
	hello_layer = HelloWorld()
	# Now we create a .Scene and pass our HelloWorld() object stored in hello_layer, as a child
	main_scene = cocos.scene.Scene(hello_layer)
	# All setup now. Let's run our main_scene
	cocos.director.director.run(main_scene)
	# The above could have been compacted to:
	# cocos.director.director.run(cocos.scene.Scene(HelloWorld()))
if __name__ == '__main__': main()
KLL
Fri Mar 16, 2018 12:55 pm
your code works here!
( you deleted only the headerline, no problem as long you not want to start it by "./test.py" )
actually i have no idea whats wrong with your system...
