JohnOtto wrote: ↑Wed Mar 14, 2018 9:49 pm
... the problem is our optical distance is longer about 100m but this module can loud only 500m for multimode fiber, is there any compensation modules available to bust the optical signal ?
As has already been mentioned this isn't really an on topic post for these forums, but::
You may find it works over a longer than allowed distance so you could try, but it's also possible you might get intermittent issues. There may be repeater modules but these would likely be sdi compatible - you should probably talk to your supplier.
500m will be the limit for that type of fibre based on the speed of switching that's used, you may get a slightly longer distance by changing the type of drivers used (in networking you'd be changing sx modules to lx ones but that's only a small increase in distance). The normal way to get more distance would be to change to singlemode fibre (which also normally means changing the driver modules).
The distance limits are all about how the light bounces within the fibre.
