Perhaps because you're going to have people using the boards that could turn the wireless back on, and you don't want that to be able to be done?alphanumeric wrote: ↑Sun Mar 18, 2018 7:19 pmWhy not just use a 3B+ and turn off the WIFI? Instead of getting a soldering iron out? Not meaning to start anything, just honestly wondering why go to the trouble of de soldering stuff you can just turn off? Granted, a Pi Foundation 2B+ would likely cost less than a 3B+ but would it be worth the effort? Me personally, I'd be more interested in a 3A or 3A+ than a 2B+. I have several headless setups that don't need Ethernet or 4 USB ports. I currently us an A+ or a Pi Zero W if I need WIFI.
I will accept the statement that has been given that Pi2B sales are too low to cover any new engineering costs to design a Pi2B+. So my question becomes...What--if any--would be the implications of just manufacturing a Pi2Bv1.2 with a '2837B0 SoC instead of the earlier '2837 (unspecified stepping) one? In other words, are the two chips "pin compatible" and only require setting the pick-and-place robot to use one package instead of the other?
Now...I will grant that that would lose a big chunk of the reason for the '2837B0 package, becuase it wouldn't spread the heat nearly as well by coupling it to the board for that purpose (and, indeed, that alone might be a "show stopper" for this approach), but there should still be *some* benefit, even if it only allows a Pi2B to gain--say--100MHz to be a 1GHz board...and look shiny.
I do agree with you that a Pi3A based on the Pi3B+ is a higher priority than a Pi2B+. Indeed, I think a CM3+ and CM3L+ is a higher priority than a Pi2B+. However, if I'm going to do anything other than just let them chug along, if I were to upgrade the Pi2Bv1.1 boards I'm using, I would want to go to a Pi2B+, thank you very much. Failing that, I will wait to see what happens, oh--a year or two--after the Pi4B comes out. Perhaps *that* will cause there to be a Pi2B+ or Pi2Bv1.3. Or maybe in a year or so, a Pi2Bv1.3 will quietly appear that uses the '2837B0 so that manufacturing of the '2837 can be discontinued.
