<Offtopic type="slightly">
If all you want is Raspbian, you don't need NOOBS. Grab a copy of plain Raspbian, install a copy of Etcher (from https://etcher.io). Use Etcher to overwrite your NOOBS card with plain Raspbian (no formatting needed, no unzipping of the Raspbian download needed).
If you want multi-boot, switch from NOOBS to PINN.
</Offtopic>
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
Re: New Raspberry Pi model 3B+ 1.4 GHz, 330Mbit Ethernet, 802.11ac, PoE
Conditional filters... Config.txt.
Could we have a separate Pi3+ one.. in fact could you make all the different models conditional rather than ranges while you are at it.
No rush as I doubt many use them or know about them. Just means I need to be more careful between card swapping.
You sound like you have a fake "genuine" PSU there as the official supply is only sold in 2.5A varietiesGergmchairy wrote: ↑Thu Mar 15, 2018 2:18 pmeven though its plugged into a Genuine Pi PSU ? Granted its rated 5v 2A - not 2.5A, but suprised none the less...
Greg
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
52:4C:52:42:41
There used to be--as I recall--2A RPF PSUs, back when the Pi2B was the top of the line.Imperf3kt wrote: ↑Thu Mar 15, 2018 7:00 pmYou sound like you have a fake "genuine" PSU there as the official supply is only sold in 2.5A varietiesGergmchairy wrote: ↑Thu Mar 15, 2018 2:18 pmeven though its plugged into a Genuine Pi PSU ? Granted its rated 5v 2A - not 2.5A, but suprised none the less...
Greg
- DougieLawson
The only filters I use are based on serial number. I have a single unified /boot/config.txt for all fifteen Raspberries.
[0xssssssss]
stuff for serial ssssssss
[0xtttttttt]
stuff for serial tttttttt
[all]
dtparam=i2c=on
- FTrevorGowen
- Forum Moderator
- Contact: Website
Such as this one: http://www.cpmspectrepi.uk/raspberry_pi ... _Models.29W. H. Heydt wrote: ↑Thu Mar 15, 2018 7:12 pmThere used to be--as I recall--2A RPF PSUs, back when the Pi2B was the top of the line.Imperf3kt wrote: ↑Thu Mar 15, 2018 7:00 pmYou sound like you have a fake "genuine" PSU there as the official supply is only sold in 2.5A varietiesGergmchairy wrote: ↑Thu Mar 15, 2018 2:18 pmeven though its plugged into a Genuine Pi PSU ? Granted its rated 5v 2A - not 2.5A, but suprised none the less...
Greg
(Which "works for me"- but nothing "demanding" plugged into the USB ports.)
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, and a A+) but Buster on the P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
I'll give that a goDougieLawson wrote: ↑Thu Mar 15, 2018 7:19 pmThe only filters I use are based on serial number. I have a single unified /boot/config.txt for all fifteen Raspberries.
[0xssssssss] stuff for serial ssssssss [0xtttttttt] stuff for serial tttttttt [all] dtparam=i2c=on
Thanks.
Exactly one of those... Works fine with a 3b+ latest image!FTrevorGowen wrote: ↑Thu Mar 15, 2018 8:08 pmSuch as this one: http://www.cpmspectrepi.uk/raspberry_pi ... _Models.29W. H. Heydt wrote: ↑Thu Mar 15, 2018 7:12 pmThere used to be--as I recall--2A RPF PSUs, back when the Pi2B was the top of the line.
Trev.
Nice to see faster I/O on the 3B+ & have just put my order in for one.
Also looking forward to what sounds like the RPi4 coming in the future.
That is interesting because the website shows what appears to be a class 10 SanDisk card but no mention of the A1 rating. I suspect a better SD card will help realize the benefits of the improved networking speed of the 3B+ when used as a file server.
Along these lines, does anyone have network latency measurements for the Pi 3B+? Using the four computers a 1.4Ghz AMD Athlon, a 2.8Ghz AMD Athlon64X2, a Pi 2B and a Pi 3B connected by a 100mbit switch I obtain
Ping from Athlon to Athlon64X2 gives time=0.194 ms
Ping from Athlon to Pi 2B gives time=0.423 ms
Ping from Athlon to Pi 3B gives time=0.463 ms
I wonder if network latency decreases with the 3B+ updates and GB switch. If anyone has a GB switch, a PC, a Pi 3B and a 3B+, would it be possible to compare
Ping PC to Pi 3B
Ping PC to Pi 3B+
and report back to see if there is any improvement between the 3B and 3B+ when all are connected to the same GB switch?
Still a LONG time before that comes out...
Does it still have the annoying non-spring-loaded microsd slot?
Pity that there is still no wifi connector for external wifi antenna... rf shielding is fun with internal antenna just at side of the chip
From my tests on rpi3 (and same on rpi2 with wifi adapter connected right on a rpi usb port, without an usb extension cable) the rpi on it's own (specially when hdmi is connected, and depending on the images that will be displayed) causes considerable interference on wifi...
- Raspberry Pi Engineer & Forum Moderator
- Location: The unfashionable end of the western spiral arm of the Galaxy
Not sure how it's possible to be annoyed by it, but yes, it's the same slot. AIUI, we switched to the friction hold type because push-push slots were very fragile and resulted in increase in returns.
That rather depends on your definition of "LONG time". For my 10-year-old grandson, a year would be a long time. For me--at 68--a year isn't that long. I only worry about living long enough to see future products.
1. the push-push slot was replaced for a friction fit slot on Pi 3, 2 years ago.nars wrote: ↑Thu Mar 15, 2018 10:31 pmDoes it still have the annoying non-spring-loaded microsd slot?
Pity that there is still no wifi connector for external wifi antenna... rf shielding is fun with internal antenna just at side of the chipFrom my tests on rpi3 (and same on rpi2 with wifi adapter connected right on a rpi usb port, without an usb extension cable) the rpi on it's own (specially when hdmi is connected, and depending on the images that will be displayed) causes considerable interference on wifi...
2. you should buy a better HDMI cable if you're experiencing interference issues. I'm not sure what good an external antenna connector would do if your HDMI cable was blasting RF interference all over the place.
Rockets are loud.
https://astro-pi.org
Does anyone know if there is US stock anywhere right now? I got an order into Newark, but it looks like they have no stock. Maybe I missed the rush..
Regards,
-Moses
Regards,
-Moses
Power problems? MoPower UPS for the Pi
http://www.allspectrum.com/mopower/
Have you checked the UK sources? Shipping isn't any more expensive (and may be less) and the transit time is about the same.
also with a bit of luck it could shoot microsd cards into distance with no returns at allShiftPlusOne wrote: ↑Thu Mar 15, 2018 10:51 pmwe switched to the friction hold type because push-push slots were very fragile and resulted in increase in returns.
Ran a test: no heatsink, all four arm cores churning away overnight. The 2837 flip-chip packaging / PCB heatsink did it's job nicely - no throttling, around 67C, with the task completed in ~12 hours. That same task demands a decent heatsink & ~14 hours on a Pi3. Good job! Dare say it'll need some extra cooling mid-summer though.
Should've stated, in that test the Pi was in the vertical plane, propped on its long short edge. No case either.
Edit: correct orientation discovered on retrieving Pi3B+ this morning: Pi was stood upright on USB/ethernet sockets.
I do understand the reason for the change but it makes it rather difficult to pull the card out when it's in a case with just a hole which leaves it flush to the outside edge. The push-push connector allowed a card to be popped out using a fingernail, matchstick or similar. It is much harder to get a push-pull card out when the Pi is in a case and there's not a lot of clearance on the socket side.
Most annoying is getting used to push-pull then forgetting that older Pi's are push-push, pulling the card out and damaging the socket.
- DougieLawson
More annoying is rebooting my A+, B+ and 2B unexpectedly when I've pressed on the SDCard by accident while pulling a USB device out. Good riddance to the spring loaded slot.
I prefer the spring load, get really annoyed at the Pi3 when it been nudged in a case or similar (like the Google Voice) and doesn't start.
Bring back the spring load I say. So much easier and not having to get pliers to pull the SD card out.
- RaTTuS
- Contact: Twitter YouTube
on mine that still have only micro sdcards in I use a small sticky label on the micro sdcard to give it a bit of purchase ....
Covfefe
Covfefe
