sdjf
Re: will this USB hub work with raspberry pi?
Tue Oct 23, 2012 7:25 am
When you ask about the Hub, did you just want to use it as a hub or also as a power source?
I do not see your Hub on the list of verified peripherals, it should work as a hub, but who knows. These are the hubs that will work for sure:
http://elinux.org/RPi_VerifiedPeriphera ... d_USB_Hubs
And power supplies:
http://elinux.org/RPi_VerifiedPeriphera ... r_adapters
I am not good with knowing mini-A vs. mini-B stuff, but you might need to also get the right kind of cable with microB to plug this in to the power port on your Pi, if you want it to power the Pi.
Also, it says it will only power devices at 500mA the Pi requires 700mA.
Terminus Technology * ASIN: B003Z4G3I6
* Item model number: USB2-HUB-AG7
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
RaTTuS
Contact: Twitter YouTube
Tue Oct 23, 2012 7:28 am
it will probably work but there are plenty of others that are cheaper that will work
Covfefe
lazygregg
Tue Oct 23, 2012 2:00 pm
i dont need to plug the power from my pi into the usb hub just usb things into the powered usb hub. thanks for link
