hanchbang
Best Fedora based distro?
Tue Mar 13, 2018 6:26 am
Which is the most stable and lightweight fedora based distro?Fedberry seems a better try than pidora which was a big disappointment for me.How it's compared to Raspbian?
Re: Best Fedora based distro?
Tue Mar 13, 2018 7:29 am
If you have a RPi 2B / 3B Fedora itself, if you have an ARMv6 RPi then Fedberry.
They do not compare to Raspbian, as like Ubuntu-Mate rely on Community Support.
viewtopic.php?f=51&t=151274&p=992574
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
hanchbang
Tue Mar 13, 2018 7:39 am
I have Raspberry Pi 3 Model B.I tried to create a bootable image with the common way (dd if=*.iso of=/dev/sdb) and had no luck, also I've seen many people have the same problem and problems with camera module so I was thinking that there must be a more stable fedora based os.
jahboater
Tue Mar 13, 2018 7:52 am
Is an ".iso" the same things as a ".img" file?
hanchbang
Tue Mar 13, 2018 7:59 am
If you are asking my opinion, yes it's the same thing.
Return to “Pidora / Fedora”
