First time I've downloaded the oficial image and the RPi started, all the boot text scrolled over the screen, but it stopped after 4/5 seconds.
If I use the Logitech K400 keyboard it don't work at all, and if I use my desktop's Microsoft keyboard the RPi recognizes it but still "unbootable". I press al the keys, they appear on the screen, but the boot still stopped...
After this happened, I've downloaded the Installer. The setup work well only with my desktop's keyboard, 'cause the Logitech don't work. In the end of the setup the first problem appeared again: no boot! The RPi starts, but the OS don't.
So I've downloaded this image to see if I can solve the problem, and yes, the Raspbian booted finally and recognized the keyboard!
After that I run the "rpi-update" command which worked well until the reboot. After the reboot it won't boot again. So now I'm using an older version of the fimware and I can't install some apps (including emulators) 'cause it runs the update automatically.
Is there someone with the same problem? I like to use MAME on my TV and I can't
I hope that you could help me.
