tigernero
Raspian stretch does not reconnect to wifi after restart access point
Thu Mar 08, 2018 7:32 am
I do not understand why if I restart my access point,
Raspian stretch does not connect again remaining in No APS scanning,
I have to restart it to re-establish the connection. I did a clean installation same problem what can it be?
Re: Raspian stretch does not reconnect to wifi after restart access point
Thu Mar 08, 2018 9:35 am
Are you using a hidden SSID?
I've been testing in this area, and normal SSID would rescan fine, hidden ones needs a change to wpa_supplicant.conf.
I was using the latest firmware however, and a slightly modified linux driver (both to be released soon)
tigernero
Thu Mar 08, 2018 12:36 pm
no hidden ssid, simply wifi does not hang up anymore to its wifi after a restart of the access point, I have to restart the raspberry with raspbian to get back the wifi.
I had the problem after the latest brcm firmware updates
I solved by replacing the stretch wifi drives with those of jessy
procedure:
Download brcm_Raspbian_Jessy.rar
https://www.pensierando.it/Nextcloud/in ... LBtoeHHGsW
unzip
launch the commands
sudo mv /lib/firmware/brcm /lib/firmware/brcm-stretch
sudo mv [path_from_file]/brcm /lib/firmware/brcm
sudo apt-mark hold firmware-brcm80211 #prevent it from beeing updated
#back
#sudo apt-mark unhold firmware-brcm80211
I have the latest raspbian version which with the latest updates gave me the problem that if I restart the raspbian access point it did not reconnect.
replacing the last drives with those of jessy everything is back to work.
when will the bug be fixed?
Thu Mar 08, 2018 4:07 pm
We believe we have a fix for the crashes when rebooting an AP or using a hidden SSID. In my testing this week, with the latest firmware and Linux driver, the Pi did reconnect to a rebooted access point, except in the hidden SSID case, which required a change in wpa_supplicant (as outlined in another thread).
Not sure when this will be released. A few days I expect - it's clearly better than before.
Thu Mar 08, 2018 5:55 pm
Couldn't be any worse. I've got a couple of RPi3s that are not at all happy with WiFi. I'm willing to do a beta test if you can stick the fixed modules on Github (Gist), Google docs or Dropbox or somewhere.
Fri Mar 09, 2018 10:15 am
What you can try is the standard 4.14 with the new firmware. That combination should work and be more robust. 4.9 has a missing commit on the Linux driver that is in 4.14. Would be interested to see results.
Fri Mar 09, 2018 1:50 pm
I'm already running bdb826a8db75ba36d754bd71fb64d3905d3bd026
Linux Challenger 4.14.24-v7+ #1097 SMP Mon Mar 5 16:42:05 GMT 2018 armv7l GNU/Linux
I've been on the 4.14 kernel since it was first made available with BRANCH=next.
Fri Mar 09, 2018 2:42 pm
Is this with the new wireless firmware that we had to roll back?
tigernero
Fri Mar 09, 2018 3:07 pm
I'm still with jessy's drive instead of stretch and everything's going well,
but when will you release the updated wireless firmware I will find it with sudo apt update and dist-upgrade?
Linux raspberrypi 4.14.24-v7+ #1097 SMP Mon Mar 5 16:42:05 GMT 2018 armv7l
Fri Mar 09, 2018 3:19 pm
The release will mean that apt upgrade/update will get it.
Currently still testing.
Fri Mar 09, 2018 3:32 pm
I think I rolled it back on all of my RPi3s.
[    7.625340] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[    7.633674] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[    7.633914] usbcore: registered new interface driver brcmfmac
[    7.819713] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
[    7.820648] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.41 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-08-07 00:37:47
Fri Mar 09, 2018 3:57 pm
Hmm. 4.14 in my testing with the NEW firmware works fine. Reconnected after a AP reboot. Is it possible for you to try the newest firmware? Would appreciate any reports on that particular combination.
Fri Mar 09, 2018 4:11 pm
Is that the current minus one version from apt-get? What's the date on the firmware that I need to test. Or where can I download a zipfile?
This is the current firmware
dougie@Challenger:/lib/firmware/brcm$ strings brcmfmac43430-sdio.bin | grep 2017
Aug  7 2017
2017-08-07 00:37:47
43430a1-roml/sdio-g-p2p-pool-pno-pktfilter-keepalive-aoe-mchan-tdls-proptxstatus-ampduhostreorder-lpc-sr-bcmcps Version: 7.45.41.46 (r666254 CY) CRC: 970a33e2 Date: Mon 2017-08-07 00:48:36 PDT Ucode Ver: 1043.206
This is the version I've saved away in a "brcm_bad" folder
dougie@Challenger:/lib/firmware/brcm_bad$ strings brcmfmac43430-sdio.bin | grep 2017
Oct 23 2017
2017-10-23 03:47:14
43430a1-roml/sdio-g-pool-p2p-idsup-idauth-pno-pktfilter-wowlpf-keepalive-aoe-lpc-swdiv-srfast-fuart Version: 7.45.98.38 (r674442 CY) CRC: ffb2ee5a Date: Mon 2017-10-23 03:58:00 PDT Ucode Ver: 1043.2099 FWID 01-e58d219f
Fri Mar 09, 2018 4:49 pm
Here's the firmware in Drive, but I believe it is current apt get minus one
https://drive.google.com/open?id=11wv8o ... 8bxbHDGB47
Fri Mar 09, 2018 5:18 pm
That's the 7.45.98.38 version, so I'll give that a go over the weekend.
When it fails I'm getting this from wpa_supplicant
Successfully initialized wpa_supplicant
Failed to create interface p2p-dev-wlxb827ebd88739: -22 (Invalid argument)
nl80211: Failed to create a P2P Device interface p2p-dev-wlxb827ebd88739
P2P: Failed to enable P2P Device interface
nl80211: deinit ifname=wlxb827ebd88739 disabled_11b_rates=0
wlxb827ebd88739: CTRL-EVENT-TERMINATING
tigernero
Fri Mar 09, 2018 5:31 pm
pi@raspberrypi:/lib/firmware/brcm $ strings brcmfmac43430-sdio.bin | grep 2017
Oct 23 2017
2017-10-23 03:47:14
I just tested the brcmfmac43430-sdio.bin
from the link you have put
on my raspberry pi3
restarting the access point and it worked, after restarting it kept connecting and reconnecting.
so I can say that it worked for me
davesteele
Fri Mar 09, 2018 7:53 pm
I just tested this situation with Comitup on the latest Stretch. It reconnects to an interrupted Access Point just fine.
https://davesteele.github.io/comitup/
Return to “Raspberry Pi OS”
