jakerthegamer3
make me when key pressed
Tue Mar 06, 2018 11:36 pm
can some one make a key pressed run this that is simple and i can add my code to it and understand it
this is the code im working with
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BOARD)
pin_number = 12
GPIO.setup(pin_number, GPIO.OUT)
frequency_hertz = 50
pwm = GPIO.PWM(pin_number, frequency_hertz)
left_position = 0.40
right_position = 2.5
middle_position = (right_position - left_position) / 2 + left_position
positionList = [left_position, middle_position]
ms_per_cycle = 1000 / frequency_hertz
for position in positionList:
		duty_cycle_percentage = position * 100 / ms_per_cycle
		print("Position: " + str(position))
		print("Duty Cycle: " + str(duty_cycle_percentage))
		print("")
		pwm.start(duty_cycle_percentage)
		time.sleep(.5)
pwm.stop()
GPIO.cleanup()
pcmanbob
Re: make me when key pressed
Wed Mar 07, 2018 12:23 pm
Hi.
First when posting code please use code tags.
Add [code] at the top
code goes here
and [/code] at the bottom.
second your request for help is some what vague, do you want to run the program and then wait for a specific key to be pressed, or are you wanting to make the key press start the program say from the desktop.
please be more specific in your request.
mahjongg
Wed Mar 07, 2018 5:22 pm
added code tags.
Return to “Python”
