robdog12
Installing numpy python3
Mon Mar 05, 2018 6:44 am
I am new to raspberry pie and need to install numpy, pandas, script and Matplotlib for python3. When I install numpy with
pip3 install numpy
it installs ok. When I try to import numpy within python3 code I get the error
Original error was: libf77blas.so.3: cannot open shared object file: No such file or dircetory
Without numpy working none of the other packages which are dependent on numpy work either.
I have been trying to fix this for three days and have reinstalled Rasparian 4 times but I haven't made any real progress.
Does anyone know how to fix this?
KLL
Re: Installing numpy python3
Mon Mar 05, 2018 11:36 am
did you try (but i not tested)?
From the terminal run:
sudo apt-get install python3-numpy
For for plotting graphs use pylab:
sudo apt-get install python3-matplotlib
scotty101
Mon Mar 05, 2018 11:58 am
Try installing it with piwheels
https://www.raspberrypi.org/blog/piwheels/
This should be quicker once setup as it will find a version of numpy that is built for the raspberry pi rather than having to build it from source.
robdog12
Fri Mar 09, 2018 3:04 am
Hi KLL and Scottie101,
I had previously tried the:
But previously I made the mistake of not removing the broken version of numpy before attempting to install using apt-get. This meant it didn't install because it registered a version of numpy already installed.
To remove the old version of numpy:
pip3 uninstall numpy
Once I removed numpy I could install it using KLL's recommended method.
Thanks for your help it is all working now.
ben_nuttall
Thu Sep 27, 2018 9:58 pm
It's not very clear but this shows that a shared object file is missing. The numpy you get from piwheels depends on libatlas.
When installing numpy using pip, you also need to install libatlas3-base:
sudo apt install libatlas3-base
sudo pip3 install numpy
I wrote about this process on the piwheels blog, hope it helps: https://blog.piwheels.org/how-to-work-o ... n-package/
Why choose to pip install from piwheels instead of using apt? It's a much newer version, and new releases are available quickly. The version in Debian/Raspbian is older and will not be updated besides whole distro upgrades like Jessie -> Stretch.
Community Manager - Raspberry Pi Foundation
Author of GPIO Zero and creator of piwheels
Chris.KB3CS
Wed Nov 28, 2018 5:57 pm
i did not use pip3 to install numpy and the apt repo served up the latest version of numpy.
i had the same missing libf77blas.so error until i did "apt install libatlas3-base" .. then numpy (and matplotlib) started working immediately. ;)
