natmendes
i2c problem - two slaves with same address
Fri Mar 02, 2018 7:50 pm
Hi everyone! Im trying to use two infrared temperature sensor mlx90615. They use i2c communication.
My ideia is to get one temperature by second. But, as they are the same device, they have the same address, so i can not recognize from which sensor RPi is getting temperature.
I dont know how to separate them to say in code 'first get this one, and then get the other one'.
Im using bcm2835.
Can anyone help me?
Thank you!
joan
Re: i2c problem - two slaves with same address
Fri Mar 02, 2018 9:28 pm
You have a number of choices. The two easiest are probably
Buy a multiplexer chip such as the TCA9548A to choose between the devices.
Create a software I2C bus on a couple of spare GPIO and connect one device to the hardware bus and the other to the software bus.
Search through /boot/overlays/README for some information on these options.
dgordon42
Fri Mar 02, 2018 10:12 pm
The mlx90615 device stores it's I2c address in it's EEPROM, and so you can change it to allow multiple mlx90615 devices on a single I2c Bus.
Details on page 9 of the datasheet
Hope this helps,
Dave.
