jbeale
[SOLVED] 3TB NTFS hard drive not supported?
Fri Mar 02, 2018 5:31 am
UPDATE: Solved. Working fine after doing the magic incantation of:
sudo apt-get install ntfs-3g
Problem: I did not realize that the RPi-3 with current Raspbian does not support larger USB hard drives such as 3 TB with NTFS. Is there any workaround for this? I already have a lot of data on it, so I'd rather not reformat it to something else.
Solution: install ntfs-3g package, See above.
[380853.728197] scsi 0:0:0:0: Direct-Access     TOSHIBA  External USB 3.0 5438 PQ: 0 ANSI: 6
[380853.730767] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[380853.731112] sd 0:0:0:0: [sda] 5860533164 512-byte logical blocks: (3.00 TB/2.73 TiB)
[380853.731123] sd 0:0:0:0: [sda] 4096-byte physical blocks
[380853.731584] sd 0:0:0:0: [sda] Write Protect is off
[380853.731592] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[380853.732025] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[380853.738388] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[380853.760892] sd 0:0:0:0: Attached scsi generic sg0 type 0
[380853.795355]  sda: sda1 sda2
[380853.798328] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[380853.799766] sd 0:0:0:0: [sda] Attached SCSI disk
[380854.681324] ntfs: driver 2.1.32 [Flags: R/W MODULE].
[380854.723125] ntfs: (device sda2): parse_ntfs_boot_sector(): Volume size (2TiB) is too large for this architecture.  Maximum supported is 2TiB.  Sorry.
[380854.723136] ntfs: (device sda2): ntfs_fill_super(): Unsupported NTFS filesystem.
