ilovehd
Turn WIFI on from the command line - Still off
Fri Feb 23, 2018 7:43 pm
Model 3 running Jessie - I am trying to turn the wifi on from the command line.
I have tried ifup wlan0, and its still off.
iwconfig shows wlan0
if i click Image in the GUI to turn the wifi on it works no problem.
How do I do this from the command line?
Thanks!
pcmanbob
Re: Turn WIFI on from the command line - Still off
Fri Feb 23, 2018 9:44 pm
Try
ifconfig wlan0 up
Or
sudo ifconfig wlan0 up
ilovehd
Mon Feb 26, 2018 11:45 am
when I try that command I get a message:
SIOCSIFFLAGS: Operation not possible due to RF-kill
Any other ideas?
rfkill list returns these results
0: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
ilovehd
Mon Feb 26, 2018 12:02 pm
I resolved the issue by issuing the following command:
sudo rfkill unblock 0
Thanks all !
PiGraham
Mon Feb 26, 2018 12:06 pm
[Edit] I see OP found this solution before I posted but I'll post anyway for the detail.
How did you turn Wi-Fi off?
A search on rfkill led here
http://www.geekmind.net/2011/01/linux-w ... e-due.html
Pi has no hardware button so that stuff is irrelevant but maybe this is useful:
What does this report?
sudo rfkill list all
My PiZeroW gives this:
[email protected]:~ $ sudo rfkill list all
	Soft blocked: no
	Hard blocked: no
1: hci0: Bluetooth
	Soft blocked: yes
	Hard blocked: no
If it reports blocked maybe this will unblock it:
That's using the number for the interface listed above
The Soft blocked status seems to correspond to the GUI "Turn Wi-Fi on" / "Turn Wi-Fi off".
