Hello all,
I have a USB controller that works perfectly when connected to my PiZeroW running Jesse on 4.9.35+ kernel
[ 248.070169] usb 1-1: new low-speed USB device number 13 using dwc_otg
[ 248.071015] Indeed it is in host mode hprt0 = 00041901
[ 248.334288] usb 1-1: New USB device found, idVendor=0079, idProduct=0011
[ 248.334308] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 248.334319] usb 1-1: Product: USB Gamepad
[ 248.357363] input: USB Gamepad as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.0/0003:0079:0011.0003/input/input3
[ 248.359324] dragonrise 0003:0079:0011.0003: input,hidraw0: USB HID v1.10 Joystick [USB Gamepad ] on usb-20980000.usb-1/input0
I purchased a powered hub from AmazonBasics https://www.amazon.com/dp/B00DQFGH80. When I connect the controller through this, I seem to be getting what I understand are power limitation issues?
[ 5204.039810] Indeed it is in host mode hprt0 = 00021501
[ 5204.259744] usb 1-1: new high-speed USB device number 14 using dwc_otg
[ 5204.260169] Indeed it is in host mode hprt0 = 00001101
[ 5204.512626] usb 1-1: New USB device found, idVendor=2109, idProduct=2811
[ 5204.512642] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5204.512650] usb 1-1: Product: USB2.0 Hub
[ 5204.512656] usb 1-1: Manufacturer: VIA Labs, Inc.
[ 5204.518095] hub 1-1:1.0: USB hub found
[ 5204.518396] hub 1-1:1.0: 4 ports detected
[ 5214.060448] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[ 5214.599669] usb 1-1.2: new low-speed USB device number 15 using dwc_otg
[ 5214.709693] usb 1-1.2: device descriptor read/64, error -71
[ 5214.939734] usb 1-1.2: device descriptor read/64, error -71
[ 5215.169801] usb 1-1.2: new low-speed USB device number 16 using dwc_otg
[ 5215.279708] usb 1-1.2: device descriptor read/64, error -71
[ 5215.509843] usb 1-1.2: device descriptor read/64, error -71
[ 5215.739846] usb 1-1.2: new low-speed USB device number 17 using dwc_otg
[ 5216.179818] usb 1-1.2: device not accepting address 17, error -71
[ 5216.289693] usb 1-1.2: new low-speed USB device number 18 using dwc_otg
[ 5216.729818] usb 1-1.2: device not accepting address 18, error -71
[ 5216.730295] usb 1-1-port2: unable to enumerate USB device
Can someone suggest how to get this going? Thanks!
