I have a Pi3, I am having a problem with dnsmasq not giving IP I believe, my client gets "Failed to obtain IP address" when it connects to the AP.
root@raspberrypi:~# lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 9.3 (stretch)
Release: 9.3
Codename: stretch
I've got hostapd and dnsmasq installed. I see the ssid.
What I am trying to accomplish:
I have openvpn connected to my vpn service. My initial plan was to use this for my roku stick so I could use the VPN to connect to other regions. Plan A was this was going to be a second gateway routing through the vpn tunnel (had that working) but couldn't use that due to limitation on the Roku so plan B was to get the PI setup as another wifi. Eth0 is on my regular network, tunnel is the default tun0:
root@raspberrypi:~# ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.11 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::2fe8:3cc5:be0:252d prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:dd:b2:1d txqueuelen 1000 (Ethernet)
RX packets 10891 bytes 749228 (731.6 KiB)
RX errors 0 dropped 7 overruns 0 frame 0
TX packets 5557 bytes 1078166 (1.0 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 18 bytes 1615 (1.5 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 18 bytes 1615 (1.5 KiB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 172.21.22.131 netmask 255.255.254.0 destination 172.21.22.131
inet6 fe80::5d05:318:6106:a2eb prefixlen 64 scopeid 0x20<link>
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 100 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
TX packets 3 bytes 144 (144.0 B)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.4.1 netmask 255.255.255.0 broadcast 192.168.4.255
inet6 fe80::7c1b:2537:50ba:a1f0 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:88:e7:48 txqueuelen 1000 (Ethernet)
RX packets 140 bytes 21745 (21.2 KiB)
RX errors 0 dropped 11 overruns 0 frame 0
TX packets 53 bytes 8397 (8.2 KiB)
I plan to setup iptables to do the forwarding. I've changed so much and there is a lot of info out there but what I think is the simplest piece of this is giving me grief. (Probably should start over)
All I see for entries grep for masq in the syslog are:
Feb 20 18:13:17 raspberrypi systemd[1]: Stopping dnsmasq - A lightweight DHCP and caching DNS server...
Feb 20 18:13:17 raspberrypi dnsmasq[1110]: Too few arguments.
Feb 20 18:13:17 raspberrypi dnsmasq[533]: exiting on receipt of SIGTERM
Feb 20 18:13:17 raspberrypi systemd[1]: Stopped dnsmasq - A lightweight DHCP and caching DNS server.
Feb 20 18:13:45 raspberrypi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Feb 20 18:13:45 raspberrypi dnsmasq[1190]: dnsmasq: syntax check OK.
Feb 20 18:13:45 raspberrypi dnsmasq[1201]: started, version 2.76 cachesize 150
Feb 20 18:13:45 raspberrypi dnsmasq[1201]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Feb 20 18:13:45 raspberrypi dnsmasq-dhcp[1201]: DHCP, IP range 192.168.4.20 -- 192.168.4.100, lease time 12h
Feb 20 18:13:45 raspberrypi dnsmasq[1201]: reading /run/dnsmasq/resolv.conf
Feb 20 18:13:45 raspberrypi dnsmasq[1201]: using nameserver 8.8.8.8#53
Feb 20 18:13:45 raspberrypi dnsmasq[1201]: read /etc/hosts - 5 addresses
Feb 20 18:13:45 raspberrypi dnsmasq[1202]: Too few arguments.
Feb 20 18:13:45 raspberrypi systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
Feb 20 18:23:23 raspberrypi systemd[1]: Stopping dnsmasq - A lightweight DHCP and caching DNS server...
Feb 20 18:23:23 raspberrypi dnsmasq[1374]: Too few arguments.
Feb 20 18:23:23 raspberrypi dnsmasq[1201]: exiting on receipt of SIGTERM
Feb 20 18:23:23 raspberrypi systemd[1]: Stopped dnsmasq - A lightweight DHCP and caching DNS server.
Feb 20 18:23:31 raspberrypi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Feb 20 18:23:31 raspberrypi dnsmasq[1449]: dnsmasq: syntax check OK.
Feb 20 18:23:31 raspberrypi dnsmasq[1460]: started, version 2.76 cachesize 150
Feb 20 18:23:31 raspberrypi dnsmasq[1460]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Feb 20 18:23:31 raspberrypi dnsmasq-dhcp[1460]: DHCP, IP range 192.168.4.20 -- 192.168.4.100, lease time 12h
Feb 20 18:23:31 raspberrypi dnsmasq[1460]: reading /run/dnsmasq/resolv.conf
Feb 20 18:23:31 raspberrypi dnsmasq[1460]: using nameserver 8.8.8.8#53
Feb 20 18:23:31 raspberrypi dnsmasq[1460]: read /etc/hosts - 5 addresses
Feb 20 18:23:32 raspberrypi dnsmasq[1461]: Too few arguments.
Feb 20 18:23:32 raspberrypi systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
Only thing I see is the too few arguments message but the service is running .. would expect to get an IP on the device just internet access to be broken potentially.
root@raspberrypi:~# service dnsmasq status
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2018-02-20 18:23:32 UTC; 2h 52min ago
Process: 1374 ExecStop=/etc/init.d/dnsmasq systemd-stop-resolvconf (code=exited, status=0/SUCCESS)
Process: 1461 ExecStartPost=/etc/init.d/dnsmasq systemd-start-resolvconf (code=exited, status=0/SUCCES
Process: 1452 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=0/SUCCESS)
Process: 1449 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS)
Main PID: 1460 (dnsmasq)
CGroup: /system.slice/dnsmasq.service
└─1460 /usr/sbin/dnsmasq -x /run/dnsmasq/dnsmasq.pid -u dnsmasq -r /run/dnsmasq/resolv.conf -
