allen2345k
My Raspberry Pi 3b no longer recognize my USB pen drive
Mon Feb 19, 2018 12:34 pm
I have installed the latest Raspbian and everything was working fine until I remove some packages from add/remove software. After that, my Pi3 can no longer recognize any USB pen drives. I hope someone can help me to bring it back. I don't want to reinstall the Raspbian again because it will take me a long time to install everything back.
Thank you.
MaxK1
Re: My Raspberry Pi 3b no longer recognize my USB pen drive
Mon Feb 19, 2018 1:46 pm
boot your pi normally and when it is up and running, plug the USB stick in. Open a terminal and type dmesg If there is anything in there about /dev/sda, paste that here.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
FTrevorGowen
Mon Feb 19, 2018 5:50 pm
Thank you.
What does the lsusb and usb-devices commands report with & w/o a usb drive plugged in? (To put it another way - is a drive being detected but not being mounted and seen by the filemanager perhaps, rather than "not being recognised")
Trev.
HawaiianPi
Mon Feb 19, 2018 6:56 pm
I have installed the latest Raspbian and everything was working fine until I remove some packages...
What software did you remove?
