Hi there,
First time poster, be gentle. I've being working with some raspberry pi's at work, and I've discovered a problem with some of the raspberry pi touchscreens. Thought I might check if anyone else has encountered the problem and has a fix.
It appears that the touchscreen has a dead touch column (in Portrait mode, I guess it would be row if held landscape) straight in the middle of the screen, which is a problem because there's buttons in the center that I need to press. It appears to work intermittently however, as after a series of touches at varying pressure it eventually works.
If pertinent the application I'm running is a web page in Flask, but it appears to be affected across more than just that app.
Any ideas?
