rego21
UDEV on the last Raspbian
Fri Feb 16, 2018 4:16 pm
Hello all,
Im trying to make an udev rule able to detect whenever a usb device is connected and then run a script. However it doesn´t work at all, here is the udeve rule:
ACTION=="add", RUN="/home/pi/device.sh
And the script:
#!/bin/bash     date >> log.log
Thank you all!
topguy
Re: UDEV on the last Raspbian
Fri Feb 16, 2018 5:31 pm
- I think you need to add something to your rule that matches this USB device.
Example: SUBSYSTEMS=="usb",DRIVERS=="qcserial"
This matches modem which uses the Qualcom driver.
or: ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001"
This matches only USB devices with these two attribute values. These two you can see with "lsusb" .
Also:
- The script can not run for a long time. It will be killed by systemd.
- It can not spawn off a separate script in the background either, that too will be killed by systemd.
You script looks OK, but you are missing a " in your rule, but I'm guessing that might be a cut&paste error.
rego21
Fri Feb 16, 2018 5:48 pm
@topguy but i cant make a generic udev rule? I´m new with this, can you guide me please?
topguy
Fri Feb 16, 2018 6:25 pm
Never tried to make generic rules with udev, my goal has always been to match a specific device and give it a good name or something.
I'm not sure what happens when multiple rules matches for example.
Maybe this could work ??
SUBSYSTEMS=="usb",  RUN+="/home/pi/device.sh"
rego21
Sat Feb 17, 2018 9:13 am
Ok gonna give it a try @topguy!
rego21
Sat Feb 17, 2018 11:11 am
Somehow my first rule worked, but dont know how, because i try to plug in and out my usb keyboard and nothing works... I also tried your rule, but no success @topguy...
rego21
Sat Feb 17, 2018 11:50 am
Ok very strange, my rule is working now but i dont know why ahah Thanks for your help @topguy!
