yingyong25
Fan or heatsink for overclocking the pi3
Thu Feb 15, 2018 10:48 am
What shall i use to stop my pi from heating up when overclocking? :D
MaxK1
Re: Fan or heatsink for overclocking the pi3
Thu Feb 15, 2018 11:41 am
I use heatsinks and fans - all my pi's (and a tinkerboard) run at about 40'C - 45'c with 2 cores running 100%, one of the pi's is overclocked to 1.440GHz.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
Imperf3kt
Thu Feb 15, 2018 9:37 pm
I don't overclock my Pi and I need a heatsink + fan, so I would suggest a heatsink + fan. That, or liquid cooling
Stop plugging your fan directly into the GPIO 5v
https://www.electronics-tutorials.ws/power/transient-suppression.html
runboy93
Thu Feb 15, 2018 10:19 pm
Aluminum case with included heatsink feature + thermal pads (or copper sheet + paste)
henryww
Sun Aug 12, 2018 2:04 pm
I have experimented with several different heatsinks, cases and fans.
A big aluminium heatsink is better than those little copper heatsinks you can find on ebay and they are even better with a fan, any cheap fan will help however noctua make a 5v fan perfect for the pi if you can find a way to mount it.
Noctua do two version of the 5v fan which you can run off the Raspberry pi's 5v and ground GPIO pins.
Quiet and better than any fan that comes with a cheap Raspi case
https://noctua.at/en/products/fan/nf-a4x10-5v
Twice the thickness, higher airflow, louder.
https://noctua.at/en/products/fan/nf-a4x20-5v
If you are not a fan of fans the FLIRC case does a superb cooling job, I have one on an overclocked Raspberry pi 2 and it stays under 60 degrees c easily.
The Nespi case by Retroflag is also a great case and comes with a fan, I recommend installing heatsinks on the raspberry pi though. My Nespi has a 3B+ inside it OC'd to 1550Mhz CPU and 550Mhz GPU and never goes higher than 59 degrees c.
Imperf3kt
Sun Aug 12, 2018 11:37 pm
I'm curious, have you ever actually reached those fogures in a real-world scenario? For example, does it run stable at 100% CPU use?
henryww
Mon Aug 13, 2018 1:35 pm
Yeah I ran stress with 4 threads and GLXgears, while playing some youtube music in the background for 2 hours, htop reported 100% CPU usage on all cores the whole time and the max temperature was 59.1 C.
I can always retest and post pictures if you wish.
Imperf3kt
Tue Aug 14, 2018 12:27 am
The Pi3b+ throttles at 60℃, this is why I was asking if you were getting those actual figures.
henryww
Tue Aug 14, 2018 11:54 am
:roll:
I really think you should read the documentation.
https://www.raspberrypi.org/documentati ... agement.md
What you are referring to is just a software limitation this can be increased by adding
temp_soft_limit=
to config.txt
All Raspberry Pi's have a hard limit of 85℃ as stated in the documentation .
It just so happens my max temperature was coincidentally just below 60℃, please do not make assumptions about my setup.
Here are some sysbench scores to back me up:
1400Mhz
Test execution summary:
    total time:                          79.9525s
    total number of events:              10000
    total time taken by event execution: 319.7542
    per-request statistics:
         min:                                 31.62ms
         avg:                                 31.98ms
         max:                                 87.83ms
         approx.  95 percentile:              32.15ms
Threads fairness:
    events (avg/stddev):           2500.0000/14.37
    execution time (avg/stddev):   79.9386/0.01
1500Mhz
    total time:                          74.9147s
    total time taken by event execution: 299.6043
         min:                                 29.51ms
         avg:                                 29.96ms
         max:                                 94.65ms
         approx.  95 percentile:              30.53ms
Threads fairness:
    events (avg/stddev):           2500.0000/28.39
    execution time (avg/stddev):   74.9011/0.01
1550Mhz
    total time:                          72.1991s
    total time taken by event execution: 288.7382
         min:                                 28.55ms
         avg:                                 28.87ms
         max:                                 83.03ms
         approx.  95 percentile:              28.99ms
Threads fairness:
    events (avg/stddev):           2500.0000/12.90
    execution time (avg/stddev):   72.1845/0.01
And my config.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
arm_freq=1550
sdram_freq=500
over_voltage=8
gpu_freq=550
temp_soft_limit=70
temp_limit=80 #Will throttle to default clock speed if hit.
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
# NOOBS Auto-generated Settings:
gpu_mem=128
By the way the ambient temperature in my house is 16℃ which certainly helps.
jahboater
Tue Aug 14, 2018 12:46 pm
Please could you try this and report the temp (from "vcgencmd measure_temp") after half an hour?
wget https://raw.githubusercontent.com/ssvb/cpuburn-arm/master/cpuburn-a53.S
gcc -o cpuburn-a53 cpuburn-a53.S
./cpuburn-a53
This little monitor script may be usedful:
#!/bin/bash
Counter=14
DisplayHeader="Time      Temp    CPU        Throttle        Vcore"
while true ; do
  let Counter++
  if [ ${Counter} -eq 15 ]; then
    echo -e "${DisplayHeader}"
    Counter=0
  fi
  Health=$(perl -e "printf \"%19b\n\", $(vcgencmd get_throttled | cut -f2 -d=)")
  Temp=$(vcgencmd measure_temp | cut -f2 -d=)
  RealClockspeed=$(vcgencmd measure_clock arm | awk -F"=" '{printf ("%0.0f",$2/1000000); }' )
  CoreVoltage=$(vcgencmd measure_volts | cut -f2 -d= | sed 's/000//')
  echo -e "$(date '+%H:%M:%S') ${Temp} $(printf '%4s' ${RealClockspeed})MHz $(printf '%019d' ${Health}) ${CoreVoltage}"
  sleep 10
done
jahboater
Tue Aug 14, 2018 12:51 pm
I found this heat sink to be very effective:
https://www.amazon.co.uk/Kintaro-Raspbe ... o+heatsink
Its large, but low profile, and importantly because it is bolted on, it uses proper thermal paste instead if sticky tape.
Its the best I have found so far for the Pi.
RaTTuS
Tue Aug 14, 2018 2:40 pm
Covfefe
Imperf3kt
Wed Aug 15, 2018 1:44 am
:roll:
temp_soft_limit=
to config.txt
I am aware of that, but had assumed you were not, because you gave no indication otherwise.
I'm sorry if I offended you, its just I was scheptical as I've never heard of a Pi going beyond 1500MHz and remaining stable. I have no idea how you set up your Pi, so was forced to make assumptions based on the information provided.
I may have to try your config myself if I ever get a Pi3b+, my ambient temperature here is sub zero :D
klondike_bars
Mon Sep 10, 2018 6:27 am
henryww
Do you mind sharing the links you used for the heatsinks and fan for the Retroflag case? I see this link https://www.amazon.com/Retroflag-Functi ... BVACS9JS6N Not sure if those pads are recommended.
It would be much appreciated.
Thanks in advance.
HawaiianPi
Tue Sep 11, 2018 5:32 pm
I'm not a fan of fans. They require additional power, create noise, and over time they will fill your system with dust.
I have most of my Pi3B(+) computers in the Flirc Gen2 case (picture is link).
The case itself acts as a huge heatsink that keeps my Pi3B and 3B+ computers running cool, without the noise, dust, and additional power use of fans (and it looks very cool as well). The 2nd generation Flirc is made specifically for the Raspberry Pi 3B and 3B+ computers, and should include thermal pads for both (the newer 3B+ requires a thinner thermal pad).
Return to “Advanced users”
