hupaa
U4 in raspberry pi3 model B
Mon Feb 12, 2018 11:41 am
I need the datasheet of "V36hB" signed by U4 on raspberry pi3 model B.
I don't know what is this chip?
could you please guide me
thanks.
klricks
Re: U4 in raspberry pi3 model B
Mon Feb 12, 2018 1:11 pm
thanks.
U4 is on the schematic at grid location 2-C: https://www.raspberrypi.org/documentati ... matics.pdf
The part number for U4 as shown on the schematic is: APX803-46SAG
Its purpose is to turn off the red power LED via Q1 when the supply voltage drops below 4.63V
MaxK1
Mon Feb 12, 2018 3:02 pm
That's the 2nd time in about a week somebody has asked about that part - Is there a soldering problem at the factory?
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
hupaa
Wed Feb 14, 2018 6:28 am
thanks.
Thanks a lot. how can I set this answer as "solved"?
hupaa
Wed Feb 14, 2018 6:31 am
I think this happen because the part number on the chip is different from that in schematic
the part number on chip is "V36hB", while the part number in the schematic is "APX803-46SAG" .
there is no datasheet for "V36hB" and so if you can not access to schematic you can not understand what is "U4" and can not access to its datasheet
MaxK1
Wed Feb 14, 2018 7:29 am
I made an assumption based on some previous posts (My bad!) where U4 had been knocked off the board.
RaTTuS
Contact: Twitter YouTube
Wed Feb 14, 2018 9:08 am
edit the original post
Covfefe
shakes
Sat Aug 25, 2018 7:08 am
Hello!
Since i have an issue with that smd component ( its loose ) i hijack this thread.
What would be the easiest replacement? Can i just remove it completely? Are there better or other quick options?
W. H. Heydt
Sat Aug 25, 2018 4:59 pm
Hello!
Welcome to the forums.
If you want the PWR LED to work correctly, you need this component to be there. See other comments in the thread for exactly what it is and what it does.
shakes
Sun Aug 26, 2018 9:05 pm
Hey, thanks i started it with soldered power supply and it works well no problems. If i find opportunity to buy this chip i ll solder it, till then ;)
