browntastic
DPI screen datasheet
Sun Feb 11, 2018 7:29 pm
I'm trying to drive an LCD using the Raspberry Pi GPIO pins with the DPI Kippah. I've been following the Adafruit tutorial https://learn.adafruit.com/adafruit-dpi ... ah-ttl-tft. I looked at the data sheet for the example screen, and it has different pinouts than the screen I have http://www.datasheetspdf.com/pdf/788923 ... 6TN53-V1/1. Will I have to modify the DPI device tree blob, or is this something that can only be solved through physical wiring?
Also, how do I generate the dpi_output_format hex value? There is some information here https://www.raspberrypi.org/documentati ... /README.md, but I don't understand where the "magic number" comes from.
aBUGSworstnightmare
Re: DPI screen datasheet
Mon Feb 12, 2018 10:36 am
you will need an adapter PCB - converting Kippah pinout to your Innolux Display pinout.
Better opt for designing your 'own Kippah' for this module (as effort needed for both options is the same)
browntastic
Tue Feb 13, 2018 11:11 pm
I was afraid of that.
Any idea about the dpi_output_format hex value?
