lazloman
Using piclone to clone openhabian
Sat Feb 10, 2018 7:06 pm
I asked this in the OpenHAB forums, but got answers, so I'm trying here:
I have OH2 (openhabian) running on an RPi3 on a 64GB thumb drive. I’d like to copy the installation to a smaller, 16GB drive. I tried using piclone, but when I try to run it, I get a permissions error. So I launched it using
sudo piclone
as well as
sudo su -
piclone
but when launching it through either of those methods, piclone does not see either the boot or target drives. I was able to test piclone successfully on a Pi that does not have OH2 installed, so I know it can work, but I’m not sure how to proceed under openhabian. Does anyone have any ideas?
MaxK1
Re: Using piclone to clone openhabian
Sat Feb 10, 2018 7:37 pm
You can use rsync or tar to back it up/restore it. Not sure why piclone wouldn't run, though...
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
lazloman
Tue Feb 13, 2018 12:52 am
Will using either of those tools make it bootable?
MaxK1
Tue Feb 13, 2018 10:37 am
No - for that you would need to shrink the image and use dd (or something similar)
lazloman
Tue Feb 27, 2018 2:16 am
Here is the answer:
sudo dbus-launch piclone
The technical explanation is here:
https://github.com/raspberrypi-ui/piclone/issues/12
Return to “Beginners”
