mattwynne
Blinking HDMI output on Samsung TV
Wed Feb 07, 2018 12:35 pm
We have a new Raspberry Pi with NOOBs on it. We set it up with the default desktop OS.
It works fine on a HDMI monitor in my office, but when plugged into the TV (also via HDMI), the display blinks black briefly every second or so. It's regular, and I think I can see it doing it during boot up as well as once the OS is loaded.
It's plugged directly into the TV and I have tried other cables etc.
I've fiddled around with the settings in /boot/config.txt quite a bit to no avail, trying different groups and modes, and upping the boost. Even in safe mode it does the same thing (just with a daft big resolution).
I feel like I'm missing something. Where else could I look to try and diagnose this?
Thanks in advance!
MaxK1
Re: Blinking HDMI output on Samsung TV
Wed Feb 07, 2018 4:09 pm
Are you using the same PSU and cable?
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
