In section "Prepare Linux host", point "Install dependencies" you have to install pythonVolodymyr wrote: ↑Tue Mar 27, 2018 6:27 pm[email protected]:/opt/qt5pi$ sysroot-relativelinks.py sysroot
bash: /usr/bin/python: No such file or directory
-no-icu
target.path = /home/pi
INSTALLS += target
/home/pi/application/Application: error while loading shared libraries: libQt5Charts.so.5: cannot open shared object file: No such file or directory
-device linux-rasp-pi3-g++
-no-use-gold-linker
qt-everywhere-src-5.10.1.tar.xz
Because my tutorial is for 5.7.1 and they changed some things in later versions. For up-to-date tutorial, take a look in german forum.
/opt/qt5pi/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/arm-linux-gnueabihf/include/c++/4.8.3/arm-linux-gnueabihf/bits/os_defines.h:39:22: fatal error: features.h: No such file or directory
#include <features.h>
compilation terminated.
Makefile:198: recipe for target 'atomicfptr.o' failed
make: *** [atomicfptr.o] Error 1
std::atomic for function pointers disabled.
ERROR: detected a std::atomic implementation that fails for function pointers.
Please apply the patch corresponding to your Standard Library vendor, found in
/opt/qt5pi/qt-everywhere-opensource-src-5.7.1/qtbase/config.tests/common/atomicfptr
Maybe something is wrong with the sysroot folder /opt/qt5pi/sysroot
/opt/qt5pi/sysroot/usr/local/qt5pi/bin/qmake
./spotify-client: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by ./spotify-client)
./spotify-client: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by ./spotify-client)
./spotify-client: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/qt5pi/lib/libQt5Gui.so.5)
./spotify-client: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/qt5pi/lib/libQt5Qml.so.5)
./spotify-client: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/qt5pi/lib/libQt5WebSockets.so.5)
./spotify-client: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/qt5pi/lib/libQt5NetworkAuth.so.5)
./spotify-client: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/qt5pi/lib/libQt5Network.so.5)
./spotify-client: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/qt5pi/lib/libQt5Test.so.5)
./spotify-client: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `CXXABI_1.3.9' not found (required by /usr/local/qt5pi/lib/libQt5Core.so.5)
./spotify-client: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /usr/local/qt5pi/lib/libQt5Core.so.5)
[email protected]:~ $ ./qopenglwidget -platform xcb
QFontDatabase: Cannot find font directory /usr/local/qt5pi/lib/fonts.
Note that Qt no longer ships fonts. Deploy some (from http://dejavu-fonts.org for example) or switch to fontconfig.
QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
QOpenGLWidget: Failed to create context
composeAndFlush: QOpenGLContext creation failed
composeAndFlush: makeCurrent() failed // <-application closed here
QXcbIntegration: Cannot create platform offscreen surface, neither GLX nor EGL are enabled
../qt-everywhere-opensource-src-5.7.1/configure -opengl es2 -device linux-rasp-pi-g++ -device-option CROSS_COMPILE=arm-linux-gnueabihf- -sysroot /opt/qt5pi/sysroot -prefix /usr/local/qt5pi -opensource -confirm-license -skip qtwebengine -skip qtscript -nomake examples -make libs -v
+ cd qtbase
+ /home/ojanguren/qt-everywhere-opensource-src-5.7.1/qtbase/configure -top-level -opengl es2 -device linux-rasp-pi-g++ -device-option CROSS_COMPILE=arm-linux-gnueabihf- -sysroot /opt/qt5pi/sysroot -prefix /usr/local/qt5pi -opensource -confirm-license -skip qtwebengine -skip qtscript -nomake examples -make libs -v
You don't seem to have 'make' or 'gmake' in your PATH.
Cannot proceed.
../qt-everywhere-src-5.11.2/configure -opengl es2 -device rasp-pi3-g++ -device-option CROSS_COMPILE=arm-linux-gnueabihf- -sysroot /home/paul/raspi/sysroot -I/home/paul/raspi/sysroot/usr/include/ -L/home/paul/raspi/sysroot/usr/lib/arm-linux-gnueabihf -opensource -confirm-license -make libs -prefix /usr/local/qt5pi -extprefix ~/raspi/qt5pi -hostprefix ~/raspi/qt5 -v -no-use-gold-linker -nomake examples -no-compile-examples -nomake tests -skip qtwayland -skip qtwebengine -sql-mysql MYSQL_INCDIR=~/raspi/sysroot/usr/include/mysql MYSQL_LIBDIR=~/raspi/sysroot/usr/lib/arm-linux-gnueabihf
/home/paul/raspi/qt-everywhere-src-5.11.2/qtbase/src/corelib/io/qfilesystemengine_unix.cpp: In static member function ‘static bool QFileSystemEngine::renameFile(const QFileSystemEntry&, const QFileSystemEntry&, QSystemError&)’:
/home/paul/raspi/qt-everywhere-src-5.11.2/qtbase/src/corelib/io/qfilesystemengine_unix.cpp:1286:19: error: ‘AT_FDCWD’ was not declared in this scope
if (renameat2(AT_FDCWD, srcPath, AT_FDCWD, tgtPath, RENAME_NOREPLACE) == 0)
/home/paul/raspi/qt-everywhere-src-5.11.2/qtbase/src/corelib/io/qfilesystemengine_unix.cpp:1286:19: note: suggested alternative: ‘QT_GETCWD’
QT_GETCWD
/home/paul/raspi/qt-everywhere-src-5.11.2/qtbase/src/corelib/io/qfilesystemengine_unix.cpp: At global scope:
/home/paul/raspi/qt-everywhere-src-5.11.2/qtbase/src/corelib/io/qfilesystemengine_unix.cpp:115:12: warning: ‘int statx(int, const char*, int, unsigned int, statx*)’ defined but not used [-Wunused-function]
static int statx(int dirfd, const char *pathname, int flag, unsigned mask, struct statx *statxbuf)
/home/paul/raspi/qt-everywhere-src-5.11.2/qtbase/src/corelib/io/qfilesystemengine_unix.cpp:109:12: warning: ‘int renameat2(int, const char*, int, const char*, unsigned int)’ defined but not used [-Wunused-function]
static int renameat2(int oldfd, const char *oldpath, int newfd, const char *newpath, unsigned flags)
Makefile:30263: recipe for target '.obj/qfilesystemengine_unix.o' failed
make[3]: *** [.obj/qfilesystemengine_unix.o] Error 1
make[3]: Leaving directory '/home/paul/raspi/qt5build/qtbase/src/corelib'
Makefile:224: recipe for target 'sub-corelib-make_first' failed
make[2]: *** [sub-corelib-make_first] Error 2
make[2]: *** Waiting for unfinished jobs....
g++ -Wl,--gc-sections -Wl,-O1 -o ../../../bin/qdbusxml2cpp .obj/qdbusxml2cpp.o -L/home/paul/raspi/qt5build/qtbase/lib -lQt5BootstrapDBus -lQt5Bootstrap -lpthread
make[3]: Leaving directory '/home/paul/raspi/qt5build/qtbase/src/tools/qdbusxml2cpp'
make[2]: Leaving directory '/home/paul/raspi/qt5build/qtbase/src'
Makefile:48: recipe for target 'sub-src-make_first' failed
make[1]: *** [sub-src-make_first] Error 2
make[1]: Leaving directory '/home/paul/raspi/qt5build/qtbase'
Makefile:81: recipe for target 'module-qtbase-make_first' failed
make: *** [module-qtbase-make_first] Error 2
