hender6688
Hiii, I have a problem with my raspberry and i need your help
Sat Feb 03, 2018 4:52 pm
Hello whoever is reading this I have a big problem what happens to me is that my raspberry pi 3 after a fall with the casing on does not want to recognize anything that is connected in one of its ports
usb for this reason does not recognize me neither mouse nor keyboard, I'm worried please respond :oops:
pcmanbob
Re: Hiii, I have a problem with my raspberry and i need your help
Sat Feb 03, 2018 8:42 pm
Hi.
Well if your pi took a fall then you should be looking for any damage done to the Pi PCB, components on it or to the USB port its self.
as we cant see you Pi you will have to do this your self.
mahjongg
Mon Feb 05, 2018 1:11 pm
If its an older (first generation) PI 1, then the quartz crystal of the LAN9512 might be dislocated, no other components are quite as sensitive to g-forces. Later models omit the crystal entirely.
sometimes tapping on the crystal, (located on the bottom side underneath the LAN9512) or heating it with a soldering iron helps.
pcmanbob
Mon Feb 05, 2018 1:20 pm
Not relevant clearly states "I have a big problem what happens to me is that my raspberry pi 3 after a fall"
mahjongg
Mon Feb 05, 2018 6:25 pm
well, then I cant help him....
This is the only *invisible* damage that I know of that can occur, and that disables the USB ports.
MaxK1
Tue Feb 06, 2018 12:39 pm
If it is only 1 port it shouldn't affect the mouse AND keyboard. Without seeing the Pi, I would suggest either living with only 3 ports, getting a an external (powered) USB hub or re-flowing the solder to the affected. Or use a bluetooth keyboard/glidepad (Fintie makes a nice one - super thin)
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
