1uke_
Pi Zero W - Headless Set-up issue (ssh and wpa-supplicant.conf files)
Sat Feb 03, 2018 3:59 pm
I have a new Raspberry Pi Zero W.
I have burnt Raspbian Stretch Lite to the SD Card using etcher on my Mac
I have added a blank file called 'ssh'
I have also added a file called 'wpa-supplicant.conf'
Based on the information towards the bottom of this thread I have added the following to the 'wpa-supplicant.conf' file -viewtopic.php?f=28&t=176844
network={
	ssid="your SSID"
	psk="your WPA2 passphrase"
But the Raspberry Pi Zero W is not showing up on my network.
What next steps can I take to fix this issue?
Just to mention I also have a Raspberry Pi 2 - so if I can do some set up using the the Pi 2 and then transfer the card over to the Pi Zero W that would be possible.
Thanks in advance.
klricks
Re: Pi Zero W - Headless Set-up issue (ssh and wpa-supplicant.conf files)
Sat Feb 03, 2018 4:10 pm
The wpa config is not complete.
Change country to match your location.
update_config=1
country=US
network={
        ssid="Your_SSID"
        psk="Your_PSK"
        key_mgmt=WPA-PSK
ddmitry1973
Sat Feb 03, 2018 4:39 pm
.... and make sure you have put
auto wlan0
as first line of wlan configuration section in /etc/network/interfaces
1uke_
Sat Feb 03, 2018 5:00 pm
OK I have followed everything you have said @klricks but it is still not showing up on my network.
Any thoughts on what I can try next?
1uke_
Sat Feb 03, 2018 5:02 pm
Thanks for the tip @ddmitry1973
how do I find /etc/network/interfaces?
Remember that I can't ssh in yet.
I am only able to access the SD card via my Mac at the moment at I can't see /etc/network/interfaces.
Let me know if there is another way for me to access /etc/network/interfaces
Thank you.
klricks
Sat Feb 03, 2018 5:15 pm
In router setup:
Encryption must be WPA or WPA2 not WEP
Make sure the SSID is not hidden.
Make sure WIFI is set to 2.4GHz or mixed (5G & 2.4G)
DO NOT change anything in /etc/network/interfaces !!!!
scruss
Sat Feb 03, 2018 7:51 pm
auto wlan0
I have never needed to do this for headless setup. It's also really hard to do on Mac & Windows, as you can't see the non-FAT partition
Pronouns: he/him
PhatFil
Sat Feb 03, 2018 8:32 pm
For good measure if not already done so give your router/AP and dhcp server a reboot. spent a few hours chassing my tail with a similar issue which resolved itself with a router reboot..
1uke_
Sat Feb 03, 2018 9:19 pm
Hi and thanks for the reply @klricks
I have set up the wpa-suplicant.conf with the details you provided.
I updated my country code.
I also updated
key_mgmt=WPA-PSK to key_mgmt=WPA2-PSK as I think my system used WPA2.
Below are my wifi settings so you can get a clearer understanding.
1uke_
Sun Feb 04, 2018 10:05 am
Just wanted to add I have checked my wifi network and I can see my security is set to WPA2-Personal.
In my wpa-supplicant.conf file I have updated to the following
key_mgmt=WPA-PSK
to
key_mgmt=WPA2-PSK
jbudd
Sun Feb 04, 2018 10:12 am
key_mgmt=WPA-PSK is the default so you don't need this line at all.
WPA-PSK is the right setting for both WPA and WPA2
