I just bought a Raspberry Pi3 Model B and wrote my first python application.
However, for programming I just connect it to TV via HDMI. When I run the program though I disconnect the TV and run my Pi standalone.
Problem: After some time, which I havent figured out yet, screen resolution changes and thonny, on which I run the program on, is being quit. Plus to that, when I try to run the py file from the command line, it does not work properly and any command will not be carried out except for the print("") command.
Im really desperate about this so thank you so much in advance for answering.
