I am looking for a simple (hopefully!) solution to duplicating screen content from one Pi to another.
To explain I have room(A) which contains Pi(A) and a connected monitor via HDMI.
I then have room(B) which has another monitor (could also have another Pi if required)
I want the same screen content to play in room(b) as is playing in the monitor on room(A)
I want to avoid using VNC as I already use this to connect to the Pi in room(A) from another PC and will probably this would mean 2 inbound connections to Pi(A) which I would prefer to avoid.
Running an HDMI splitter and an HDMI cable to monitor B is not an option due to the layout of the two rooms.
I have read a bit about screencasting and it looks difficult (maybe even impossible...)
The other posts I have read all seem to be about extending screens which is "slightly" different than what I am looking for as essentially I just want a duplicate the content on monitor(A).
I guess I am looking for something that will send the image over the air. The image does not need to HD its just a timer with some text that changes occasionally.
Does anyone have a solution that might work or can point me in the right direction, I am not adverse to more hardware/cost within reason, just need something as easy as possible to setup and reliable.
