ricardo.santos
Help with datetime.strftime
Fri Feb 02, 2018 10:15 am
Don't be to hard on me. I now this should be basic. I'm a newbie
I want to calculate a duration between a starting date and current date.
My starting date is in a dictionary (as string)
why my code doen't run?
from datetime import datetime
init_data = {'date': '2015-08-30','time': '15:35:20'}
init_date_time = init_data['date'] + ' ' + init_data['time']
init_date_time_f = datetime.strftime(init_date_time, '%Y-%m-%d %H:%M:%S')
duration = datetime.now() - init_date_time_f
fredoll
Re: Help with datetime.strftime
Fri Feb 02, 2018 10:48 am
It would be easier to help you if you give the error that you see ;-)
B.Goode
Fri Feb 02, 2018 10:55 am
I genuinely don't know, but you could check by reading the documentation for the library: can the datetime module do date arithmetic on quantities that are stored as strings?
ricardo.santos
Fri Feb 02, 2018 11:09 am
the code error is
TypeError: descriptor 'strftime' requires a 'datetime.date' object but received a 'str'
the problem is the conversion of string to date time (function strftime)
ricardo.santos
Fri Feb 02, 2018 11:11 am
WTF
the problem is that the function is strptime and not strftime
dear god!!!!
PingoBags
Fri Feb 02, 2018 11:49 am
strptime converts string to a datetime object
strftime converts datetime object to string
DTNow = datetime.now().replace(microsecond=0)
DTThen = datetime.strptime('2015-08-30 15:35:20', '%Y-%m-%d %H:%M:%S')
print(DTNow - DTThen)
or using your code
DTThen = datetime.strptime(init_date_time, '%Y-%m-%d %H:%M:%S')
scotty101
Fri Feb 02, 2018 12:14 pm
Based on PingoBags's answer, there is an alternative way to do it that doesn't involve joining the date and time together to a string first.
myDate = datetime.strptime(init_data['date'],'%Y-%m-%d').date()      #Get a date object
myTime = datetime.strptime(init_data['time'],'%H:%M:%S').time()      #Get a time object
myDateTime = datetime.combine(myDate,myTime)                         #Combine time and data objects to create a datetime object
scruss
Fri Feb 02, 2018 2:03 pm
Or another way to do it (as There Is More That One Way To Do It), with more 'Do What I Mean':
import dateutil.parser
duration = datetime.now() - dateutil.parser.parse(init_date_time)
You'll need to install dateutil, which is in the repos
sudo apt install python3-dateutil python-dateutil
Parsing dates is always a bit hacky, but it's easy until you meet time zones and Americans ...
Pronouns: he/him
ricardo.santos
Fri Feb 02, 2018 4:37 pm
many thanks.
Now i have plenty of options
Return to “Python”
