ronakmd
Difference in RASPBIAN STRETCH WITH DESKTOP and RASPBIAN STRETCH LITE.
Thu Feb 01, 2018 9:03 am
Can anyone tell me the difference between RASPBIAN STRETCH WITH DESKTOP and RASPBIAN STRETCH LITE.
Thank you.
RaTTuS
Re: Difference in RASPBIAN STRETCH WITH DESKTOP and RASPBIAN STRETCH LITE.
Thu Feb 01, 2018 9:10 am
Lite does not have the desktop stuff included
Covfefe
HawaiianPi
Thu Feb 01, 2018 6:41 pm
This ^
Lite is a very basic Linux OS with only a command line interface (CLI). There is no Desktop or GUI of any kind, and it does not include the educational or productivity software included with the Desktop version. To interact with the Lite version you will need to type commands. For new users and people not familiar with Linux the Desktop version is recommended.
RaTTuS
Fri Feb 02, 2018 8:23 am
you can make lite the same as desktop with a few apt-get installs.
Covfefe
deepakdeshp
Thu May 10, 2018 4:19 pm
What is the command for getting the minimum GUI?
W. H. Heydt
Thu May 10, 2018 6:10 pm
Thank you.
About 4GB.
deepakdeshp
Thu May 10, 2018 6:30 pm
Thank you.
About 4GB.
Is it difference between the sizes of installed LITE and DESKTOP?
HawaiianPi
Fri May 11, 2018 3:36 am
Depends on how minimal? You could run just openbox without an actual desktop...
To install the Raspberry Pi Desktop
sudo apt install raspberrypi-ui-mods
But that won't install the extra educational software and utilities (however, they may still be in the menu).
About 4GB.
Actually, it's closer to 2.9 GB.
The Lite version can be installed to a 4GB card (technically, it should fit on a 2GB, but it would leave almost no free space).
The Desktop version requires at least an 8GB card (due to the additional software and GUI it's about 4.6GB in size).
W. H. Heydt
Fri May 11, 2018 4:52 am
The last time I did a Lite install, the actual space it took was 1.4GB on a 2GB card. So there is room to work with. Not a huge amount, but it's not like you're going to have instant problems.
The fundamental difference between the two releases is all the stuff the Lite version leaves out that the full version includes. A major reason why the Lite version even exists is that the CM (and now the CM3) modules only have 4GB of on-board flash and it got to the point that the full version wouldn't fit. In the early days of the Pi, I used to install Raspbian on 4GB cards. You can't do that any more for the full version. On the other hand, it's getting harder to get 8GB cards these days, let alone anything smaller. (USB sticks have the same problem. I'd love to be able to get a fistful of 256KB--or even 128KB--USB sticks. They should be cheap, but you really don't see them available at all.)
gkaiseril
Fri May 11, 2018 3:05 pm
As noted the desktop full version includes all the scripts to display the desktop, all the utilities needed to configure the desktop, and scripts to interface other programs on and display using the desktop. All of the command line is available to the desktop using the terminal window. If one starts in the command line and then starts the desktop, the shut down allows returning to the command line. If one boots directly to the desktop there is no option to return to the command line.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
qualle
Mon Aug 27, 2018 3:29 am
I hope it's OK to add my question here, I feel it somehow matches the topic, but that part wasn't answered yet.
Is there a performance difference? (in terms of RAM use)
My scenario: I pretty much always use the Pi in CLi mode. But once in a while it's fun to get to the desktop. That would requite of course the desktop version.
But when there is no Desktop/UI required I like to have the full Raspbian performance. So I wonder if even in CLi use, are there any dormant UI parts active in the RAM?
I am fully aware that the space requirement on the SD card is much higher. That is no problem for me.
W. H. Heydt
Mon Aug 27, 2018 4:04 am
Basically, Lite--as it comes in the download--lack the X windowing system, so that won't be running. You can configure the Full version to boot without running X and the desktop if you want to do a comparison of RAM usage. Depending on what exactly you are doing, you could cut the amount of RAM allocated to the VC4 graphics hardware to the minimum of 16MB in either mode, but you're much more likely to get away with that (without adverse impact) if X isn't running. And, of course, when you are running fewer services, there will be less load on the CPU cores. I'm not sure you'd notice any difference, thugh.
HawaiianPi
Mon Aug 27, 2018 7:31 pm
You don't need to use the Desktop version of Raspbian, you can install raspberrypi-ui-mods to add the Desktop and required dependencies to Lite (and it will still be lighter, because it won't include loads of extra software pre-installed on the Desktop version of Raspbian).
If you configure Raspbian to boot to the CLI, then the difference in RAM use and performance should be negligible.
Of course when you are actually running the Desktop GUI it will require more RAM and may impact performance, but having it installed and not using it will use SD card space more than anything else.
DirkS
Mon Aug 27, 2018 7:35 pm
raspbberrypi-ui-mods
FTFY
Mon Aug 27, 2018 7:36 pm
FTFY
FYFFY,YW (fixed your fix for you)
This is a doctor free zone.
DirkS
Mon Aug 27, 2018 8:00 pm
FTFY
:shock: Cheers!
HawaiianPi
Tue Aug 28, 2018 1:20 pm
LOL! Sorry for the typo.
sudo apt update && sudo apt install raspberrypi-ui-mods
Will add the Raspberry Pi Desktop to Raspbian Lite.
k-pi
Wed Aug 29, 2018 10:25 am
Related questions.
Does LITE come with wifi software installed?
What is the installed size of LITE?
What is the installed size of LITE plus raspberrypi-ui-mods?
And if LITE doesn't come with wifi software, is it included in raspberrypi-ui-mods?
Wed Aug 29, 2018 10:54 am
Raspbian Lite comes with eveything you need to get WiFi up and running.
If you need something else it's just an apt-get away.
jahboater
Wed Aug 29, 2018 11:01 am
Last time I looked, there was about half the number of processes running in the Lite version.
k-pi
Wed Aug 29, 2018 12:57 pm
Thanks, Heater, knowing that makes it a much more useful way for me to get just the basics of a GUI installed. :)
HawaiianPi
Wed Aug 29, 2018 6:57 pm
When I setup a new Raspbian Lite boot device I copy a pre-configured wpa_supplicant.conf file onto the small FAT32 "boot" partition, which Raspbian will move to the correct location and use to connect to my WiFi when I fire up the Pi. Much easier than trying to configure a WiFi connection from the CLI. It works with any model with built-in WiFi, or with a Raspbian compatible USB WiFi dongle.
This is, of course, after writing a Raspbian image to the device (using NOOBS complicates things).
k-pi
Wed Aug 29, 2018 7:16 pm
That will make it much easier, I had just been trying to remember how to set up wifi, so I'll just make a back up copy & copy it over.
Thanks, HawaiianPi. :)
k-pi
Thu Aug 30, 2018 3:43 pm
So, an update, & answers to my previous questions.
Raspberry-stretch-lite = 1.1GB installed size.
With GUI (raspberrypi-ui-mods) = 1.6GB installed size.
Add in chromium-browser = 1.8GB installed size.
Hope that is of some use to someone else too. 8-)
JetForMe
Sat Jun 08, 2019 1:19 am
Does Raspbian Lite include Avahi, or some other way to find it to ssh into it? Or must I connect a keyboard and monitor?
