skyforever
looking for proper wpa_supplicant.conf file for multiple network
Thu Feb 01, 2018 3:37 am
Pi Zero W; 11/29 Stretch
country=US
update_config=1
network={
	ssid="nameasidojfaoisjf"
	psk="asdasdas"
network={
	ssid="nameasidojfaoisjf2"
	psk="asdasdas2"
Every works fine when there's only one network entry, whenever I try to edit in a second network entry as the example above, the pi would not be able to connect to any routers upon reboot. The only solution after that would be to place a new wpa_supplicant.conf file into boot partition with a single entry and everything works fine again, even after rebooting.
What does your multiple network wpa_supplicant.conf file in Stretch look like? What I had worked fine in Jessie.
klricks
Re: looking for proper wpa_supplicant.conf file for multiple network
Thu Feb 01, 2018 4:21 am
This works for me (RPi3B):
Tested by changing the SSID & PSK on router then restarting router. The RPI then auto connects to the active SSID after a few seconds or on reboot.
wpa file as created by GUI tool only not direct edit...
update_config=1
country=US
network={
        ssid="SSID_1"
        psk="PSK_1"
        key_mgmt=WPA-PSK
network={
        ssid="SSID_2"
        psk="PSK_2"
        key_mgmt=WPA-PSK
